  IAC question
IAC question by stewnew
Started on: 07-27-2013 04:21 PM
Replies: 1 (238 views)
Last post by: Marvin McInnis on 07-28-2013 02:42 AM
stewnew
Report this Post07-27-2013 04:21 PM Click Here to See the Profile for stewnewSend a Private Message to stewnewEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should any vacuum be felt when placing your finger over the IAC inlet in the throttle body after the IAC has closed.
I used Ogre' s method checking throttle stop adjustment to put the IAC into the closed position.
I still seem to have a reasonable vacuum acting on finger despite believing the IAC is closed.
Thanks
Marvin McInnis
Total ratings: 227
Report this Post07-28-2013 02:42 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt that the IAC is designed to seat perfectly, in which case you might indeed feel substantial vacuum with the finger test. But with the IAC closed the air volume should be very small. The next test would be to note whether there is a significant difference in idle RPM with the IAC port open or covered.
[This message has been edited by Marvin McInnis (edited 07-28-2013).]
