  Switch for sound located above dome lights
Switch for sound located above dome lights by 86 Vintage Fiero
Started on: 07-24-2013 12:39 PM
Replies: 5 (1248 views)
Last post by: 30+mpg on 07-25-2013 01:14 PM
86 Vintage Fiero
Report this Post07-24-2013 12:39 PM Click Here to See the Profile for 86 Vintage FieroSend a Private Message to 86 Vintage FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought my 86 GT last year and PO stated that the original radio was going bad so they replaced it with a new radio. My question is I noticed there is a switch above the dome lights. On the switch it has written "Performance Sound - Min / Max". Apparently it has been unhooked because I see no difference when the switch is moved from to right to left or versus. Can anyone explain what is should do?
TXGOOD
Total ratings: 87
Report this Post07-24-2013 12:44 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look up in the right footwell and see if there is a subwoofer box.
Below is compliments of Fierosails
http://www.fierosails.com/Speakers.html
[This message has been edited by TXGOOD (edited 07-24-2013).]
Fiero84Freak
Report this Post07-24-2013 12:50 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Performance Sound" is an option that added an adjustable subwoofer to the stock stereo setup. Since by the time Performance Sound came around it was an add-on, GM/Pontiac just kind of placed it in the most accessibly and easy-to-throw-into space of the car - under the passenger-side of the dash. If you simply look in the foot well area in the passenger-side, you should clearly see the subwoofer protruding from under the dash.
If the prior owner installed a new stereo into the car, then there is a high likelihood the provisions for Performance Sound were not re-installed into the new stereo correctly or something else was done to prevent it from working correctly.
86 Vintage Fiero
Report this Post07-25-2013 09:27 AM Click Here to See the Profile for 86 Vintage FieroSend a Private Message to 86 Vintage FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, the information you have is unbelievable.
jaskispyder
Total ratings: 205
Report this Post07-25-2013 09:34 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, you can hook it back up to the stereo, if you have the amp. Otherwise, you can get a sub amp and connect it. Check the speaker, as it may be bad.
30+mpg
Total ratings: 97
Report this Post07-25-2013 01:14 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
No fairy tales there. All fact. You can believe it or not, your choice.
[This message has been edited by 30+mpg (edited 07-25-2013).]
