  DCA 883459596 Rear View Mirror Wirring Help
DCA 883459596 Rear View Mirror Wirring Help by whitestar
Started on: 07-18-2013 09:51 AM
Replies: 2 (2683 views)
Last post by: whitestar on 07-19-2013 03:59 PM
whitestar
Report this Post07-18-2013 09:51 AM Click Here to See the Profile for whitestarSend a Private Message to whitestarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got a deal on this mirror to go in the Fiero and have searched high and low, with not much luck. It is E11 015607 with 16 pin wire hardness. Mirror has power button, button with small white circle, On Star button, and Red Plus sign with a star in the middle of it. Any help would be appreciated!
Pins 1-4 Empty
Pin 5 Pin Light Gray
Pin 6 Light Green with Black Stripe
Pin 7 Brown
Pin 8 Black
Pin 9 Light Green
Pin 10 Empty
Pin 11 Dark Green with White Stripe
Pin 12 Light Green with Black Stripe
Pin 13 Pink
Pin 14 Yellow with Black Stripe
Pin 15 Brown with White Stripe
Pin 16 Pink
Ry86GT
Report this Post07-18-2013 11:24 AM Click Here to See the Profile for Ry86GTSend a Private Message to Ry86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure this is 100% the same as yours as I see a couple of differences, but it seems to be very close and usually it's just a wiring colour change for different production years. I know most of these mirrors with similar connectors have very similar wiring schematics.
For your auto-dim to work you will need to connect pin 8 (black) to ground and pin 13 (yellow or pink) to ign +12v. You do not want the mirror on a constant +12v because that will leave it on all the time and it will drain your battery.
If the mirror has a compass it will be built in and it will work with only the power connected as above.
If you want your mirror to automatically shut off the auto-dim feature when you put the car in reverse you have to connect pin 9 (light green) to the +12v in the reverse lamp circuit.
If the mirror has temp display you will need to connect the appropriate temp sensor to pins 6 ( light green/black for sensor +12v) and 7 (Grey for sensor GND)
The rest will not be used without supporting equipment from the vehicle it was originally installed in (OnStar, Cell phone integration, etc.)
You can bench test basic mirror operation by connecting a 12V source to the power and GND circuits.
- Covering the light imput sensor will simulate a dark road and the mirror should be clear
- Un-covering the light imput sensor and shinging a flashlight on the mirror should cause it to dim
- Covering the light sensor back up with your finger should cause it to go back to clear
- With the flashlight on the light sensor and the mirror dim if you connect +12v to pin 9 (light green) the mirror should un-dim. This simulates the mirror being undimmed with high ambient light when going in reverse. Likewise removing the +12v should cause the mirror to dim again
[This message has been edited by Ry86GT (edited 07-18-2013).]
whitestar
Report this Post07-19-2013 03:59 PM Click Here to See the Profile for whitestarSend a Private Message to whitestarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Ry86GT for the information and help. Is there not a way to use some of the other functions on the mirror, like the cell phone part or other?
