  Cutting springs
Cutting springs by tebailey
Started on: 07-13-2013 09:03 PM
Replies: 14 (665 views)
Last post by: zkhennings on 07-16-2013 10:22 AM
tebailey
Report this Post07-13-2013 09:03 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone lowered the front end by cutting the front springs? would like to know height to coil removal ratio.
BV MotorSports
Total ratings: 189
Report this Post07-13-2013 10:03 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have done it several times. Just make sure you use a cut off wheel, band saw etc and not a torch. Just mark one coil lower and cut. Easy peasy. You can go up to 2 coils IIRC, but thats getting pretty low. I'd also suggest you trim the bump stops. Fieros have **** for wheel travel in the front.
tebailey
Report this Post07-13-2013 10:33 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plan on using a cut off wheel, torch changes the temper in the springs, seen a lot of people screw up front suspensions that way. Just wanted to know how much one coil will lower the front end.
TWright
Report this Post07-14-2013 07:17 AM Click Here to See the Profile for TWrightSend a Private Message to TWrightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there an easy way to cut down the bump stops in front?
West Coast Fiero's recommends taking a section out of the metal "tower" that the rubber bumper sits on. But that means you have to weld the two halves back together. Is there a non-welding way to cut down the bump stops?
Khw
Total ratings: 134
Report this Post07-14-2013 11:34 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Certainly, but you won't have the rubber part in there anymore...
Seriously though, I'm not sure how long the rubber bumper is. If it's a couple of inches long, you could just cut it in half and increase travel area. If it's less than a inch then cutting it isn't going to give you much more travel and cutting and welding the tower is about all you can do.
[This message has been edited by Khw (edited 07-14-2013).]
tebailey
Report this Post07-14-2013 12:07 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a pic of what I have. You can see I could use about an inch of lowering in the front.http://kitcars.invalid_domain_due_to_malware/download/file.php?id=29This images is larger than 153600 bytes. Click to view.
trotterlg
Report this Post07-14-2013 12:12 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, you are right, you do need to do soemthing to it. Larry
Lou6t4gto
Report this Post07-14-2013 03:40 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
If all you want is to lower it 1 inch, Cut 1 coil off the stock springs. you won't have to cut the bumper stops. it'll still ride fine.
tebailey
Report this Post07-14-2013 04:42 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That was what I wanted to know, one coil 1". Thanks.
zkhennings
Report this Post07-15-2013 08:51 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
With one coil cut off I can fit one and a half fingers in between the top of the wheel and fender with stock 88 GT wheels and tires. I had to trim the bump stops because the front end would bottom out on almost everything. I cut and re welded the cone removing around an inch of material. I would say the rubber stops are about an inch long but I felt better cutting that metal cone instead of trimming the rubber, it was jarring enough with that inch of rubber there, remove that and I feel your car would come apart bit by bit over every bump.
n7vrz
Report this Post07-15-2013 10:41 AM Click Here to See the Profile for n7vrzSend a Private Message to n7vrzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Instead of cutting spring coils and thereby reducing suspension travel, why not install Rodney's lowering ball joints?
tebailey
Report this Post07-15-2013 05:58 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Price, cutting springs $0, lowering ball joints $$$
n7vrz
Report this Post07-15-2013 09:47 PM Click Here to See the Profile for n7vrzSend a Private Message to n7vrzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cutting and rewelding bumps stops. $$$
Cutting wheels and welding supplies ain't free.
tebailey
Report this Post07-15-2013 10:09 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are for me. I get mine supplied by my employer.
zkhennings
Report this Post07-16-2013 10:22 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Win
