  Intermittant CHECK ENGINE LIGHT - 3800SC
Intermittant CHECK ENGINE LIGHT - 3800SC by PaulJK
Started on: 07-09-2013 08:20 PM
Replies: 7 (344 views)
Last post by: phonedawgz on 07-12-2013 09:13 PM
PaulJK
Total ratings: 237
Report this Post07-09-2013 08:20 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
3800SC with 4 speed auto from 1999 Grand Prix GTP. Every once in a while the engine has a "hunting idle" 900 to 1600 rpm, gas mileage drops and the CHECK ENGINE light comes ON. Drive it for a while , idle returns to normal and the engine light goes out.
Yesterday the problem returned. Today I had the codes checked: P650, P135 and P102. The guy cleared the codes, the engine light stayed out and all is well. Any ideas - is there one single thing / sensor that might be going bad to cause all 3 of these codes ?
[This message has been edited by PaulJK (edited 07-09-2013).]
sco77
Report this Post07-09-2013 09:19 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe MAF.... 3800 should never have a "hunting idle"
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV) Build Progress eta: 8/13
98 GTP - Some mods
Total ratings: 290
Report this Post07-10-2013 12:00 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
OBD2 codes are 4 digit. Assuming the leading zero...
P0102 Mass or Volume Air Flow Circuit Low Input
Perhaps an issue with your MAF wiring?
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
I don't believe the 99 Grand Prix used PCM controlled O2 heaters.
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
But your MIL light appears to be working correct?
PaulJK
Total ratings: 237
Report this Post07-10-2013 12:25 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
yep, those are the codes and descriptions the guy pulled up.
i can check the MAF wiring. the sensor is in the large tubing near the air intake canister, correct ?
i think maybe mine does (?)
All i have is a CHECK ENGINE light and it appears to be working correctly. Assuming the MIL = CHECK ENGINE, how would i check the "circuit" ?
[This message has been edited by PaulJK (edited 07-10-2013).]
IIKool
Report this Post07-10-2013 07:21 AM Click Here to See the Profile for IIKoolSend a Private Message to IIKoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the code PO135 is what you have listed,
PaulJK
Total ratings: 237
Report this Post07-11-2013 07:19 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine light went out and car runs great.
Lou6t4gto
Report this Post07-12-2013 01:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isn't the MAF on the side of the Throttle Body on the SC engine ?
Total ratings: 290
Report this Post07-12-2013 09:13 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
That flat black thing on the top of the throttle body.
