  What clicks when you use a turn signal?
What clicks when you use a turn signal? by Shonyman32
Started on: 07-08-2013 05:44 AM
Replies: 9 (307 views)
Last post by: Rodney on 07-10-2013 04:40 PM
Shonyman32
Report this Post07-08-2013 05:44 AM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
I want my car not to click when using the turn signal. Just light up.
Report this Post07-08-2013 07:15 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The flasher produces the clicking noise. Its located on the outer left side of the steering column support.
cebix
Report this Post07-08-2013 07:18 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bimetallic contacts click inside the flasher. You can wrap something around the flasher to dampen the sound - it's under the steering column. Other than that pretty much the only way to go is to get an electronic relayless flasher which uses a speaker for clicks and just hack it off.
Shonyman32
Report this Post07-09-2013 12:47 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not the answer I wanted to hear but thanks none the less. I will try to at least muffle it.
Ill at least be able to locate the sound now.
Report this Post07-09-2013 05:42 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or you can turn up the stereo!
92wastheyear
Report this Post07-09-2013 06:07 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
The first time my 17 yr old rode in mine (a few weeks ago), is something to the effect: "Is that an analog clicking for the blinkers? Cool"
rogergarrison
Total ratings: 551
Report this Post07-09-2013 07:08 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems to me Ive seen aftermarket flashers that dont click. I dont know why you dont want it though since its designed to make the sound because its easy to forget there on when you use it on the freeway...especially if the suns hitting your dash and you dont see the lights. I can live with the click, but many cars now sound chimes like seat belt warnings when you have the turn signal on...that is annoying as hell.
[This message has been edited by rogergarrison (edited 07-09-2013).]
Report this Post07-10-2013 08:07 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"They" want Blinkers making noise tho that people won't leave the signal on for miles.
Option:
Unclip flasher. Flasher makes more noise clipped or lay on trim panels.
Change flasher. Different designs often make different noise etc.
Note... Don't use OE clip on plastic flasher. OE clip's teeth can eat holes in the plastic and often short out.
hercimer01
Report this Post07-10-2013 01:43 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the newer flashers are digital. They are silent and have good brisk flash.
You can get them at any parts store.
88 Coupe under construction
Rodney
Total ratings: 267
Report this Post07-10-2013 04:40 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many years ago I watched a clip on TV showing a view a camera mounted between the seats in a Ferrari Testarossa. Every time the driver used the turn signal it clicked reasonably loud and bold. Years later I was driving in my friends little Toyota pick up and his flasher was louder than anything I generally have ever heard. So I went to a Toyota dealer and bought a flasher like his. I cut off the top of the plastic cap. Put a screen over it just in case and mounted it on a very thing steel plate bolted only on one end to the fuse box. Now I have a much louder, bolder turn signal sound in my 88 Mera. Any little thing I can do to make it more realistic.
Rodney Dickman
1988 Mera
