  heated o2 sensor
heated o2 sensor by marot
Started on: 07-03-2013 01:59 PM
Replies: 5 (939 views)
Last post by: Francis T on 07-05-2013 08:29 PM
marot
Report this Post07-03-2013 01:59 PM Click Here to See the Profile for marotSend a Private Message to marotEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi did somebody put a heated o2 sensor instead of the regular o2 sensor, if so which heated o2 sensor has the same tread as the regular one, thanks
Francis T
Total ratings: 119
Report this Post07-03-2013 03:58 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use this one and advise our header customers to replace their stock unit with as it will make the engine run better when cold.
http://www.usautoparts.net/...S-3000&x=-390&y=-217
trueleo.com
RSpiderII@aol.com
IIKool
Report this Post07-05-2013 07:49 AM Click Here to See the Profile for IIKoolSend a Private Message to IIKoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the different between a heated sensor and a non heated sensor? I'm having problem with the 02 sensor on my 3800sc. And they don't have a heated or non heated sensor. Please explain.
Ang84Indy
Report this Post07-05-2013 01:23 PM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
A non-heated O2 sensor relies on exhaust heat to bring it up to temperature, and a heated O2 sensor has a built-in heater, which brings it up to operating temperature faster than a non-heated one. This allows the ECM to go to closed-loop operation sooner, reducing emissions and using less fuel. Installing a heated O2 sensor is a modification I plan to do one of these days...
lateFormula
Report this Post07-05-2013 02:05 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
All oxygen sensors use the same thread size and pitch, which is M18x1.5. If you ever shop for exhaust components to build your own exhaust you'll see that weld in O2 sensor bungs are only offered in one size, which is a universal size.
Francis T
Total ratings: 119
Report this Post07-05-2013 08:29 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
For those contemplating such you can weld a nut with the same thread -same as oil pan plug- to you down pipe and then use any o2 you want. That's how we do them on pour headers.
trueleo.com
RSpiderII@aol.com
