  Door jam dome light switch
Door jam dome light switch by raysr11
Started on: 06-28-2013 08:19 PM
Replies: 2 (158 views)
Last post by: raysr11 on 06-29-2013 02:11 AM
raysr11
Report this Post06-28-2013 08:19 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
How do you get the plastic "knob" on the end of the switch off? I want to replace the boots on the switch. Tried light prying and pulling on it with needle nose but it refuses to give. Anyone done this before?
Another thing, my door ajar lights don't work so I removed both the switches and they both have only one wire attached, a black one with a red stripe. And the switch takes two other wires that I don't see. From the looks of the terminals on the switch they look as if nothing has ever been connected to them. My car is an '85.
Sourmug
Total ratings: 144
Report this Post06-29-2013 01:29 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
The nut around the switch comes off so you can replace the rubber boot.
Edit to add that the ground is through the frame.
[This message has been edited by Sourmug (edited 06-29-2013).]
raysr11
Report this Post06-29-2013 02:11 AM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the reply. It didn't look as if the nut would come off over the plastic knob but if it will that's great.
