  3800 bolts
3800 bolts by Lou6t4gto
Started on: 06-28-2013 07:18 PM
Replies: 6 (665 views)
Last post by: Lou6t4gto on 07-01-2013 07:24 PM
Lou6t4gto
Report this Post06-28-2013 07:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Lost the" list" someone had posted about a week ago, for "GM 3800sc Rod and Main BOLTS". I can't find the thread with search. If the person that listed it (or others) can re post the part numbers, I sure appreciate it. thanks
Lou6t4gto
Report this Post06-28-2013 07:23 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nevermind, found it.
Purple86GT
Total ratings: 62
Report this Post06-28-2013 09:42 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the link?
Robertzep2
Report this Post06-28-2013 10:43 PM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Purple...
I posted this info in a different thread awhile back when Lou originally asked about it. I collected this info for my swap:
Got some L67 engine bolt part #'s. The mains, cross bolts and rocker bolts are only available in bags of 5. So you need 2 bags of bolts for the mains & cross bolts and 3 bags for the rockers. The rod bolts are available in bags of 2, so you need 6.
Except for the Fel-Pro part, all others are GM part numbers available from a local GM dealer.
Main Bolts - 24503056
Main Cross Bolts - 24505576
Rod Bolts - 25531956
Rocker Arm Bolts - 24503515
Fel-Pro Head bolts - ES74033
Lou6t4gto
Report this Post06-30-2013 01:08 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a whole lot better. ya can get the Mains, rods, and head bolts for the price of just the rod bolts. and no machining. Thanks
cmechmann
Report this Post06-30-2013 07:44 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't get it. Did I miss something in general physics class
Have gotten the Main bolts for less than $2.00
Connecting rod bolts, less than 20% the size and weight, same metal/I think. 4 times/or more the cost?
Oh that's right, I was sleeping during the economics supply and demand class.
Lou6t4gto
Report this Post07-01-2013 07:24 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM main bolts $9 for 8. rod bolts $5 each= $60, Felpro head bolts $24 set, so $93 for ALL, Total. Arp rod bolts $90, Arp main studs $100, plus head bolts, plus machining cost. Over $415. Stock GM is my choice
