  Deck vent
Deck vent by TXGOOD
Started on: 03-05-2020 08:47 AM
Replies: 13 (496 views)
Last post by: TXGOOD on 03-09-2020 06:48 AM
TXGOOD
Total ratings: 87
Report this Post03-05-2020 08:47 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found another option for a decklid scoop.
I cut most of the existing hump out of my notchie deck lid so I had to put it toward the front to cover the hole.
It fits the contour of the decklid pretty well though and I think I`m just going to bolt it on as opposed to moulding it.
It has a rubber gasket that comes with it.
Habanera Hal
Report this Post03-05-2020 11:08 AM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a Mustang scoop? What is it off of/where did you get it? Will it clear the back glass when the lid is raised? Thanks!
TXGOOD
Total ratings: 87
Report this Post03-05-2020 11:18 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it is a Mustang scoop. There are different sizes of them though.
I picked this one because it was fairly short compared to others from the front to the back. As far as hitting the back it shouldn`t because it`s not much taller than the stock hump. That`s why I had to cut it.
[URL=https://www.amazon.com/Race-Scoops-MUSTBT-Mustang-Fiberglass/dp/B07JGGW35Q/ref=asc_df_B07JGGW35Q/?tag=hyprod-20&linkCode=df0&hvadid=331942329025&hvpos=&hvnetw=g&hvrand=813282900088951484&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028 226&h]https://www.amazon.com/Race...=&hvlocphy=9028226&h[/URL] vtargid=pla-707131157477&psc=1
[This message has been edited by TXGOOD (edited 03-05-2020).]
Report this Post03-05-2020 11:48 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut out the hump is likely cutting out the ground plane under them. 88 deck has "hidden" ground there too and now have a big hole in it.
The ground does 2 things...
Reduces E-noise from engine getting out of the bay.
Reduces E-noise getting into the engine bay from everything else.
Either can cause problems for ICM and ECM and even set bogus DTC's AKA Codes.
Put metal mesh/screen connected to ground under the scoop.
Put small screen in/near scoop opening to prevent crap getting stuck in the space. Can use black or colored Nylon or plastic here.
TXGOOD
Total ratings: 87
Report this Post03-05-2020 12:30 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just cut through the skin. The metal part is still there. I`m glad you said something as I thought it was a heat shield.
I wasn`t going to remove it anyway.
Thanks
Report this Post03-06-2020 10:06 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
85-87 Should have a ground wire to it but many terminals on the metal rusted out and loose wire from left hinge area falls down.
Vicophine
Report this Post03-06-2020 10:41 AM Click Here to See the Profile for VicophineSend a Private Message to VicophineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Following the process! May do the exact same thing, thanks for posting!
TXGOOD
Total ratings: 87
Report this Post03-06-2020 10:44 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by TXGOOD:
Thanks
85-87 Should have a ground wire to it but many terminals on the metal rusted out and loose wire from left hinge area falls down.[/QUOTE]
I was wondering about what you said because my car is an 88 but the decklid I`m doing is some earlier year.
TXGOOD
Total ratings: 87
Report this Post03-06-2020 10:46 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
TXGOOD
Member since Feb 2006
Thanks, I will post some pics of the holes I cut and measurements, etc.
Spadesluck
Report this Post03-06-2020 06:57 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks exactly like the scoop I got for mine!
Report this Post03-06-2020 07:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 has a ground "build-in" to the lid itself and I think grounds thru the hinge assembles.
I'm told GM got awards do this for 88 but little data on just how is done. I think the whole 88 lid is a ground plane unlike 84-87 that has metal parts. 84 lid vent is likely ground plane too and 85-87 have metal piece under the panel wired to car's frame.
88 lid Might not be a "real" ground so testing w/ Ω meter likely won't help. Or might but could see Hundreds of Ω to KΩ or more.
Using 85-87 lids on 88 is fine but needs the metal grounded to the frame. OE location is 1 self thread screw on bracket the left hinge is mounted to. Might still have a blank hole for this. If true, think is a punch hole w/ extra metal bend in some. Rain today and not looking.
TXGOOD
Total ratings: 87
Report this Post03-06-2020 09:57 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, I think it is.
Australian
Report this Post03-07-2020 02:25 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of fieros with this exact mod I remember threads on it.
TXGOOD
Total ratings: 87
Report this Post03-09-2020 06:48 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the grille put together.
I just need to paint it Black and it will be ready to go.
I just drilled holes in the decklid for the bottoms of the screws because when I bolt the scoop on it holds it in place.
