  LS4 oil pan
LS4 oil pan by madbrad01
Started on: 01-20-2020 09:50 AM
Replies: 18 (1253 views)
Last post by: fieroguru on 12-25-2020 08:33 AM
madbrad01
Report this Post01-20-2020 09:50 AM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
LS 4 oil pan that works on the 4t80 trans built by moroso designed by ls4 king, what do you guys think?
pmbrunelle
Total ratings: 63
Report this Post01-20-2020 12:14 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can follow the discussion on that topic here:
https://www.fiero.nl/forum/F...000123-38.html#p1488
madbrad01
Report this Post01-20-2020 12:31 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This pan lets us use the 4t80 trans
Total ratings: 260
Report this Post01-20-2020 01:33 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am sure it will work... that is how the LS4 prototypes were setup.
With needing a new pan and an aftermarket starter itis probably a $400 to $500 solution
I haven't looked at the 4T80 close enough to see if the stock LS4 starter would fit in the stock LS4 location.
madbrad01
Report this Post01-20-2020 05:39 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Aftermarket starter , Not cheap but the trans are.
sourmash
Total ratings: 50
Report this Post01-20-2020 11:15 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourcing a cheap starter should've also been the goal.
[This message has been edited by sourmash (edited 01-20-2020).]
madbrad01
Report this Post01-21-2020 05:34 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking the 4t80 trans is a good alternative for the LS4 swap. The price to build a 4t65 to hold the LS4 would cost alot more than this pan starter combo .
sourmash
Total ratings: 50
Report this Post01-21-2020 08:45 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right, but it isn't a one or the other thing. Just build it for a cheap starter since you're building it anyway. And as someone else commented regarding the drain plug location...wth?
Total ratings: 328
Report this Post01-24-2020 06:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
LS4 powertrains came from the factory attached to a 4T65eHD transmission. That is how GM designed it .
madbrad01
Report this Post01-26-2020 05:34 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the 4t65e trans is a strong enough for the ls4 , This pan will let us use the 4t80, what do you think of the added weight is going to do to the car?
sourmash
Total ratings: 50
Report this Post01-26-2020 08:56 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4t65-HD with an LS4 had 303 hp in factory fresh condition and it's known for failing under warranty. One of my 3800sc cars, a Riviera series1.5 charger(?) had a warranty replacement trans which was failing again by the drive chain slipping if you give it any throttle at all. The car had zero mods.
Total ratings: 207
Report this Post01-27-2020 10:54 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
4T60 / 4T60E holds up to a lot of torque.
GM used them behind the 4.9's with few issues.
Total ratings: 207
Report this Post01-27-2020 11:04 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
Used this pan (GM casting) on an LS1/4T65EHD
[This message has been edited by olejoedad (edited 01-27-2020).]
Total ratings: 260
Report this Post01-27-2020 02:46 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe, that is one of the prototype oil pans from the development of the LS4. So at one point GM considered the starter below the oil pan for the LS4, but opted to move it to the transmission prior to production.
Total ratings: 207
Report this Post01-28-2020 06:35 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guru, you are correct.
We also used a prototype trans to block bracket, billet aluminium with a GM P/N.
liv4God
Report this Post02-05-2020 08:14 AM Click Here to See the Profile for liv4GodSend a Private Message to liv4GodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would the oil pan allow using other manual transmissions such as the Fiero Getrag?
Total ratings: 260
Report this Post02-05-2020 06:14 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... but you will likely break it (transmission) quick.
streetrod1
Report this Post12-25-2020 04:12 AM Click Here to See the Profile for streetrod1Send a Private Message to streetrod1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is an older thread so forgive me. Can I use this oil pan with an lq9 to do my fiero swap with a 4t80e. I know it's not cheap and starter isn't as well-but I have a new gm lq9 set up with a new carb and trans controller too.I also know you can make some decent power with the ls4 but the 5.3 compared to the 6.0 is night and day difference-and if i'm gonna go through the trouble to do swap I want to run my lq9 with a 4t80e. I'm getting older lol I have huge feet and need and want an automatic !
If this style pan will work what axles do i need to use and where can I get that style pan and starter.. is it available through MOROSO now ?
Thanks gang..and Merry Christmas Everyone !
Total ratings: 260
Report this Post12-25-2020 08:33 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GM pan pictured was the prototype pan used during the development of the LS4. It was never put into production and only a handful were ever made. If you can find one, it will work.
The moroso version is only available through LS4king and you will need to contact him through facebook.
https://www.lsxmag.com/news...a-unique-ls-oil-pan/
