  3.4 push rod build 2019
3.4 push rod build 2019 by jjd2296
Started on: 12-01-2019 07:30 PM
Replies: 20 (670 views)
Last post by: La fiera on 04-24-2024 09:46 PM
jjd2296
Report this Post12-01-2019 07:30 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
[img]https://images.fiero.nl/userimages/jjd2296/E88 8AD3D-5B9D-4272-89C7-976AE3F7A39F.jpeg[/img][img]http:// images.fieroforum.com/userimages/jjd2296/9FC26AF3-E9C8-40FD-AE70-D44541395D33.jpeg[/img][img]https://images.fiero.nl/userimages/jjd2296/E0F36137-820E-4 C85-8B60-3BB86BFE4ABD.jpeg[/img][img]http://images.fiero forum.com/userimages/jjd2296/AEC0C4DB-1DBC-4C26-B9BB-BDD11378F4B0.jpeg[/img][img]https://images.fiero.nl/userimages/jjd2296/C278B5AB-592E-47ED-AB1F-0F6 82278C5CD.jpeg[/img] Just about finished my 3.4 pushrod build (thanks to local Ontario Fiero club members!).
Here’s the details:
3.4 rebuilt block
Ported heads
Sprint headers
Ported lower middle and upper intake
Bored out upper intake bracket and throttle body 57 mm
17lb injectors
RD power pulley kit
88 alternator
FS ss exhaust and high flow cat
260H cam
[This message has been edited by jjd2296 (edited 12-01-2019).]
jjd2296
Report this Post12-01-2019 07:37 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
And a spec 1 clutch
jjd2296
Report this Post12-01-2019 07:38 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
And a bored out plenum neck and TB to 57mm
jjd2296
Report this Post12-02-2019 06:53 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Next is a PPG style plenum
[This message has been edited by jjd2296 (edited 12-02-2019).]
lou_dias
Report this Post12-02-2019 10:00 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have aluminum valve cover spacers incase you wanna buy full roller 1.6 rockers from Summit.
[This message has been edited by lou_dias (edited 12-02-2019).]
lou_dias
Report this Post12-02-2019 10:06 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
Also, in the bottom part of the middle intake manifold...
I would cross-drill some holes in the tube walls right above where it meets the LIM to increase your top end. I went a little radical with my experiment here and lost a little mid range:
Flying_Dan
Report this Post12-02-2019 03:05 PM Click Here to See the Profile for Flying_DanSend a Private Message to Flying_DanEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I wold love to have an LS# in my 85' GT, I'm running a 3400 with iron heads and Fiero intake. You'll love the 3.4, it has enough of a power increase over the 2.8 you can feel it. And it all looks factory!
jjd2296
Report this Post12-02-2019 06:23 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I went this route for that reason. I wanted to look factory as mush as I could keeping the spirit of the car. My swings stage is to install a SC where the AC compressor is located. Next fall.
As for the PPG intake. The end goal is to look like this.
Report this Post12-02-2019 07:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296, I'll delete the contents of this post afterwards (so as to avoid duplication)... but if you'd like to fix the missing images in your opening post, click the EDIT tab on this post, copy everything below the dashes, then paste it into your opening post to replace the original text. (The problem in your opening post was created by not using the Enter key to put blank lines between image addresses. This then results in spaces being introduced into the middle of various image addresses.)
[EDIT] I'm not sure why you didn't make use of the edited/corrected post I supplied to replace the botched up one with the missing images at the start of this thread... but after a couple of days, it seemed there was no point leaving it here any longer, so it's been deleted.
[This message has been edited by Patrick (edited 12-05-2019).]
jjd2296
Report this Post12-02-2019 08:12 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Patrick but it seems to be a glitch with the new photo upload function from a mobile Cliff set up. No ability to hit enter etc. You just upload the pics you want and hit the upload button
Report this Post12-02-2019 08:21 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use a PC so I can't test this myself on a phone... but when you upload an image, isn't that image address then simply put into the text (wherever you happen to be) within your yet to be uploaded post? And then aren't you able to use your Enter key a couple of times to create an empty/blank line before you upload the next image?
jjd2296
Report this Post12-02-2019 08:32 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
No. Cliff upgraded the side for mobile use this week. When on a mobile there is an icon for add image you click it and you can either take a photo or select a picture from your photos on your phone. Just like with Facebook or Instagram. No more need to host the photos on another site and copy the link. I think he’s still working out the kinks.
Report this Post12-02-2019 08:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. Cliff upgraded the site...
I understand all that. I've used the new system myself! My earlier questions still apply. (I asked them in more detail Here.)
[This message has been edited by Patrick (edited 12-02-2019).]
lou_dias
Report this Post12-04-2019 02:22 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also recommend Rodney's underdrive kit with 88 alternator conversion if your car isn't an 88.
Also, the Fiero Store cross-over pipe doesn't have the D-crimp restriction where the 2 become 1. They offer one with a 2.25" down pipe but then you'd need a full 2.25" exhaust to go with it.
Also, the Fiero Store SI valves are narrowed to 7mm at the valve. You can machine the stock ones. You can also order V8 1.8" intake valves for a compression bump and I would have those narrowed to 6 or 7 mm...
jjd2296
Report this Post12-04-2019 05:08 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did RD undersrive kid with the 88 alternator. Forgot to mention that. I have SS valves as well
jjd2296
Report this Post04-02-2024 12:26 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
well the old 3.4 bit the dust. looks like I did something wrong when I installed the piston rings? anyone have a guess how the gouges got there? as a result I located another 3.4 and had it professionally built with a custom turbo cam, rebalanced, bored out 1mm, new coated pistons, heads fully done with ss valves and comp cam roller tip rockers and comp cam lifters. engine has since been boosted with a vortech v5 SC.
richard in nc
Report this Post04-02-2024 12:34 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
you couldn't just bore this engine?
[This message has been edited by richard in nc (edited 04-02-2024).]
jjd2296
Report this Post04-02-2024 03:21 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I work efficiently. This way I can drop the cradle and swap in the motor all in a day or two in the shop. Not doing it this way meant that I have a motorless car sitting for months in a shop where it can get damaged by others. And money isn't an issue for me. plus the one big gouge is borderline at 1mm, meaning if it was larger then that the block is garbage because the largest size oversize pistons available are 1mm. and because its a broken piston ring I have no idea what else is damaged inside. if its savable it will be rebuilt and kept as a spare. I have a 87 5 speed GT and an 86 ttop both with the same 3.4 sc build.
[This message has been edited by jjd2296 (edited 04-02-2024).]
cam-a-lot
Total ratings: 97
Report this Post04-02-2024 07:08 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks sexy Jeff! Need to take me for a spin this summer.... Just not on a hot day! I still can't believe you would choose a supercharger over an AC Compressor I guess I am a princess!!
Nice work!
jjd2296
Report this Post04-09-2024 07:11 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
H
[This message has been edited by jjd2296 (edited 04-09-2024).]
La fiera
Report this Post04-24-2024 09:46 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
well the old 3.4 bit the dust. looks like I did something wrong when I installed the piston rings? anyone have a guess how the gouges got there? engine has since been boosted with a vortech v5 SC.
Boost exponentially increases heat as pressure raises in the cylinder and probably the ring gap on the piston rings was set for a naturally aspirated engine. By practice when I put together a short block for boost I give it a bit more gap to compensate for the extra heat boost produces. If you don't give it that extra space once heat raises and the rings expand, since there's insufficient gap the rings ends butt against each other expand them causing drag and bending or warping or bowing of the rings and eventually breaking a piece off it. Specially if the 2nd compression ring gap was smaller than the top. And that piece could be the gouge you see on the cylinder walls.
So, ask the shop that built your new engine if they made that compensation.
Don't listen to me, listen to the experts!
https://youtu.be/_NxFRoN-Qok?si=a6UzaD_O-NTjUQMs
