  rack and pinion sources?
rack and pinion sources? by lou_dias
Started on: 10-25-2018 02:22 PM
Replies: 8 (479 views)
Last post by: Dennis LaGrua on 10-26-2018 08:02 PM
lou_dias
Report this Post10-25-2018 02:22 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
where can I buy a new or rebuilt rack and pinion of both an 87 GT and 88 Formula?
sledcaddie
Report this Post10-25-2018 02:38 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post10-25-2018 02:52 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last time I spoke with CV Source in Buford, GA., they had a half dozen or so on the shelf. C.V. Source, Inc 3027 Summer Oak Place, Suite A -- Buford, Georgia 30518-0401. Phone: (800) 955-2953 -- Local (678) 889-4118 -- Fax: (678) 546-8692
They also make custom drive axles for engine/transmission swaps like 4t60 series transmissions.
lou_dias
Report this Post10-25-2018 03:17 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sledcaddie:
https://www.rockauto.com/en...rack+and+pinion,7388
This is for the 87 only.
RockAuto is out of stock on it. FieroStore used to carry them. All of a sudden they are no where...
88Fingers
Report this Post10-25-2018 06:51 PM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the '88 anyway, I have seen threads on here that show how to rebuild your own. New upper roller bearing, new lower ball bearing and seal, Rodney makes a nice passenger side rack bushing then a nice clean-out and re-grease. Maybe throw in new inner and outer tie rod ends and....rebuilt rack! Check out the threads. Great information.
Report this Post10-25-2018 07:47 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 84-87 racks are easily rebuilt with Rodney Dickmans bronze bushing, some grease , a careful assembly procedure that includes minor adjustment and indexing of the rack. Very occasionally the needle and ball bearing require replacement but haven't come across this as yet.
[This message has been edited by Dennis LaGrua (edited 10-25-2018).]
KMFDMFAN
Report this Post10-26-2018 01:12 PM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out this thread here...
https://www.fiero.nl/forum/Forum2/HTML/135687.html
Rebuilding an entire steering rack worked wonders on my 88GT
lou_dias
Report this Post10-26-2018 03:22 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I ordered all the parts from Rodney.
Report this Post10-26-2018 08:02 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the 87's just be sure to follow the repair manual procedure on the proper indexing of the rack to steering shaft position before installation. If the rack is not indexed the position your steering wheel will be way off when the tires point straight ahead. With the 88 rack you may be able to change the rack bushing without disassembing it.
