  got a nasty looking overflow coolant resivour or windshield washer solvant holder
got a nasty looking overflow coolant resivour or windshield washer solvant holder by mmeyer86gt/gtp
Started on: 06-22-2018 12:14 AM
Replies: 2 (721 views)
Last post by: cyrus88 on 06-22-2018 04:46 PM
mmeyer86gt/gtp
Total ratings: 73
Report this Post06-22-2018 12:14 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean them with wood bleach --- yes wood bleach
mix 2oz with 1 gallon of hot water pour into the containers and slosh around or let it sit for a couple minutes on each side then wipe the outside with a rag with the mix looks like new when completed. you can use the same amount in both containers.
When complete mix 1 oz of baking soda and warm water and do the same thing to neutralize the bleach that is left.
KissMySSFiero
Total ratings: 111
Report this Post06-22-2018 09:41 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wood bleach has Oxalic acid for the active ingredient. Same ingredient as barkeepers friend. Both are commonly used to clean stains from boats.
I find barkeepers at Walmart for a lot cheaper $2 vs $10.
I’ve never used it to clean the reservoir but might try it.
For anyone that does it, wear gloves.
SSFiero@Aol.com
cyrus88
Report this Post06-22-2018 04:46 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder if Evapo-Rust Thermocure would clean the overflow tank because it unclogged an aluminum radiator and a heater core like magic.
