  Rear Coil overs ??
Rear Coil overs ?? by 85fieroguy
Started on: 04-07-2018 11:15 AM
Replies: 8 (418 views)
Last post by: Spadesluck on 04-07-2018 09:11 PM
85fieroguy
Report this Post04-07-2018 11:15 AM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see FIEROGURU is offering Rear Coil overs.struts. What are they and what is the advantage of them over the stock rear set up ???
fierosound
Total ratings: 286
Report this Post04-07-2018 11:48 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The nicest thing about coilovers is choice of spring rates and adjustability to raise/lower the rear of the car.
DIY thread https://www.fiero.nl/forum/A...130314-2-046456.html
[This message has been edited by fierosound (edited 04-07-2018).]
Tony Kania
Total ratings: 305
Report this Post04-07-2018 12:47 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can fit wider tires and wheels.
IMSA GT
Total ratings: 250
Report this Post04-07-2018 12:59 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll say it....
If you have to ask, they're not for you.
85fieroguy
Report this Post04-07-2018 01:04 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just askin
Tony Kania
Total ratings: 305
Report this Post04-07-2018 01:48 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 85fieroguy:
Just askin
I am sure that there was happiness when IMSA posted.
IMSA GT
Total ratings: 250
Report this Post04-07-2018 03:45 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly.
To answer your question about the advantage:
1- Adjustable ride height
2- Wider wheels
3- The ability to order any spring rate that you want for a stiffer or softer ride
Report this Post04-07-2018 04:51 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by IMSA GT:
Exactly.
2- Wider wheels
Correct!
Spadesluck
Report this Post04-07-2018 09:11 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are in need of new shocks anyways you might as well go this route while you have it all apart. You can either support Fieroguru (he did all the work for you) or do them yourself How To Guide. Either way you will be happy.
