  Seat Recline Handle Failure
Seat Recline Handle Failure by VanGTP5000
Started on: 02-07-2018 12:04 PM
Replies: 7 (341 views)
Last post by: VanGTP5000 on 02-08-2018 12:02 AM
VanGTP5000
Report this Post02-07-2018 12:04 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I assume this is the result of a previous owner's attempt to remove this handle from a seat. It appears the original owner purposefully broke the tab that holds the retainer pin in order to remove the handle from the car. Does this sound about right?
-Van
[This message has been edited by VanGTP5000 (edited 02-07-2018).]
Rsvl-Rider
Report this Post02-07-2018 12:23 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never seen one fail on it's own. I don't think I have ever successfully removed one without damage like that, even after removing the pin. It might be more likely his was broken or missing and he installed a broken one from another seat.
[This message has been edited by Rsvl-Rider (edited 02-07-2018).]
VanGTP5000
Report this Post02-07-2018 12:45 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. I had read that it was impossible to remove the handles without permanent damage.
-Van
Report this Post02-07-2018 02:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had 1 fail but it was because some Chubby-Butt sat down on the thing while taking the door panel off the car.
Signed: Chubby-Butt Charlie
VanGTP5000
Report this Post02-07-2018 02:41 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Chubby-Butt,
Did you wind up replacing it with TFS version?
-Van
pmbrunelle
Total ratings: 63
Report this Post02-07-2018 06:23 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe I changed a plastic handle for a replacement from the Fiero Store, and it probably worked fine.
This was a while ago, so the details are fuzzy.
Report this Post02-07-2018 07:26 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Van, I think I actually salvaged 1 at a junk yard. That would have been back in the mid 90's. I have used TFS replacements, though. Don't remember any problems with them.
VanGTP5000
Report this Post02-08-2018 12:02 AM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered a new set from TFS.
-Van
