  What parts are unique to the 88 that won't fit the earlier models?
What parts are unique to the 88 that won't fit the earlier models? by Nextel dude
Started on: 01-17-2018 08:38 AM
Replies: 16 (427 views)
Last post by: jetsnvettes2000 on 01-20-2018 01:46 AM
Nextel dude
Report this Post01-17-2018 08:38 AM Click Here to See the Profile for Nextel dudeSend a Private Message to Nextel dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to start stocking up on hard to find stuff for future needs on my 88.
What parts are unique to the 88 that won't fit the earlier models? Brakes, suspension, etc.
I know the cradle but am unsure about the brakes and suspension parts.
Thanks
Chuck
1988 Notchback
Report this Post01-17-2018 09:47 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are major differences and there are small differences. Even the engines are different, so your best bet would be to look for a parts car just like yours.
Report this Post01-17-2018 09:49 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front cradle and everything attached to it.
Rear cradle and suspension (except struts)
Entire braking system
Under-car coolant tubes
Spaceframe is different in regards to front cradle mounting area
Alternator
Exhaust crossover, downpipe
No provisions for trunk blower
Gen 2 headlights and controller
Oil pressure gage in aux gage pod
Beechwood (brown) interior pieces
Dot matrix cluster trims
Report this Post01-17-2018 10:42 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some more not so obvious items:
Flywheel or flexplate
Crankshaft
Fuel injector harness
Y pipe
Down pipe to include everything from the flange to the exhaust tip.
Rear sway bar
Front sway bar?
Front motor mount
87 and 88 has an evap canister in the right rear fenderwell near the battery
Fuel tank is larger
Nextel dude
Report this Post01-17-2018 11:19 AM Click Here to See the Profile for Nextel dudeSend a Private Message to Nextel dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey guys thanks for the replies so far. I will make a list of items and see what I can come up with
Fierochic88
Total ratings: 152
Report this Post01-17-2018 11:40 AM Click Here to See the Profile for Fierochic88Send a Private Message to Fierochic88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the wheel bearings are also 88 specific? and perhaps the coolant crossover line?
~ Jen
Report this Post01-17-2018 01:40 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only the front hubs, and they are 'attached to the front cradle'....
The crossover pipes only differ manual trans vs. auto trans
fierofrenzy
Report this Post01-17-2018 04:27 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What about the steering wheel horn paddles ? Aren't they 88 only ?
jjd2296
Report this Post01-17-2018 04:56 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
The gen 2 headlight motors are 87 as well.
[This message has been edited by jjd2296 (edited 01-17-2018).]
jjd2296
Report this Post01-17-2018 04:57 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
Oh and larger fuel tank is for 87 and 88
Report this Post01-17-2018 06:01 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 'Rally' steering wheel was 86 and 87 also.
Mickey_Moose
Total ratings: 145
Report this Post01-17-2018 06:08 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
lumbar seat
map pocket
door pockets
headlight motors are shared with 87
inner wheel well liners
Thunderstruck GT
Total ratings: 99
Report this Post01-17-2018 06:56 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is a GT or Formula.... Front wheels (1 year only)
I made sure I saved a couple of them.
[This message has been edited by Thunderstruck GT (edited 01-17-2018).]
Nextel dude
Report this Post01-18-2018 10:47 AM Click Here to See the Profile for Nextel dudeSend a Private Message to Nextel dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone thanks for the great list of parts. Hopefully others will have benefited from this list.
Total ratings: 463
Report this Post01-19-2018 06:06 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some V6 88s have a different (square) connector on the FI harness. Some have the flat connector that the earlier V6 cars had. All of the flat connector harnesses are interchangeable.
qwikgta
Total ratings: 84
Report this Post01-19-2018 07:49 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
some more:
88 had a unique ground wire attached to the rear deck lid b/c the panel is inside the lid vs. bolted to it.
Different off-set for the front rims. (unique color)
Seat material/pattern is unique to 88.
jetsnvettes2000
Report this Post01-20-2018 01:46 AM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
coolant pipes both sides front to back.
