  flat bottom steering wheel for 85 GT
flat bottom steering wheel for 85 GT by 85fieroguy
Started on: 01-16-2018 05:53 PM
Replies: 9 (327 views)
Last post by: VanGTP5000 on 01-17-2018 04:38 PM
85fieroguy
Report this Post01-16-2018 05:53 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking to replace the stock unit. MOMO's are way too expensive. Any reasonable ideas you guys have would be appreciated.
cvxjet
Report this Post01-16-2018 07:13 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't really know if this is an improvement but have you checked "Grant steering wheels"?
ron768
Report this Post01-16-2018 11:23 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Grant flat bottom wheel in my 85. I like it but will someday get the original wheel recovered.
VanGTP5000
Report this Post01-16-2018 11:49 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
ron is there a specific adapter used for your Grant wheel. I have a Grant GT wheel in my 85 and I have a slight wiggle problem that I am pretty sure is isolated to the adapter I am using vs. anything to do with the actual column.
Thanks,
-Van
Harold James Kie
Report this Post01-17-2018 01:46 AM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Lecarra Mark 8 "thick grip" wheel that I might be talked out of. It has the Fiero logo in the horn button and was purchased specifically for my Fiero but never installed even though I did use it in a Chevy Blazer for awhile. If you wish to see what it looks like look up Lecarra on the net and scroll down to the Mark 8 thick grip wheel. It does take a bit of getting used to but once you become comfortable with it it is hard to go back to a regular steering wheel. I did not install it as it is black and my interior is tan and I did not think it looked right. They are a bit pricey when bought new.
jjd2296
Report this Post01-17-2018 08:19 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by jjd2296 (edited 01-17-2018).]
jjd2296
Report this Post01-17-2018 08:21 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
If you can find a vintage 14 inch 3 spoke nardi wood steering wheel they work great. The fiero steering wheel bracket will mount to the back of the wheel with a little modification and then you can us epoxy and mount the top portion of the fiero gt wheel housing to the wheel so so can reuse the original horn. That what I did and it gives you a great
[URL=
ron768
Report this Post01-17-2018 01:47 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
Van, I had to re-drill my adapter kit (it was also a Grant kit) to get it to fit . It still did not line up 100% correctly. I had to line it up with a 4 wheel alinement . I used lots of lock tight and torqued the screws to get it to stop the wiggle.
jjd2296
Report this Post01-17-2018 04:01 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Didn’t have to do that with my nardi wheel. Just had to bend the forks on the mount ever so slightly inward to get the screw holes to line up. Perfect!!
VanGTP5000
Report this Post01-17-2018 04:38 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ron,
I am gonna give that a shot! Thank you for the advice.
-Van
