My left headlight, when it goes down, tightens to the point that it will not open again when I turn the lights on. If, after I turn the lights off, I turn the knob till it JUST loosens, when I turn the lights on, it pops up with no problem.
Is this something that requires a rebuild, or is there some sort of adjustment that can be done?
Mine does the same thing. It's pretty annoying to have to "un-stick" the motor all the time. I disassembled the motor assemblies, and cleaned and regreased everything. It made no difference.
If the motor was disassembled, was the tiny ball bearing on the bottom of the screw shaft lost? That rides on top of an adjustment screw in the bottom of the case. The B-B is captured in the cupped ends of the screw and shaft.
I didn't know about that B-B when I rebuilt my first Gen 2 motor. I saw it laying on my work cloth and fortunately I didn't throw it away. The motor operated going down, but required a twist of the knob or a light bump on the top of the knob to get it to come up. Doing some research on the problem revealed where the bearing went and when I reinstalled it, the motor worked correctly. I don't know which was the most annoying; raising the hood to bump the motor or fighting the brushes when reassembling the motor.
Cleaning lube and adjustment of the bearing may help but likely have more problems and will die soon. If have work done before like Derlin pins more so.
Cardone makes rebuild and new motors w/ a warranty. I thing AZ used them under the store brand. New Cardone motors open/close HL in ~ 2/3 of a second. How? Not by a stopwatch... Too fast for most people... Instead I repeatedly counted ~20 frames of 30 fps video for open/close at different times from my dash cam this week using MPC-HC but any w/ frame stepping can count frames. (Engine running and cleaned/fixed many grounds including G101 and G102 a few years ago.)
I thought that Gen 2 headlights were a definitive remedy for the Gen 1 headlight woes.
Maybe it's the control module that's not shutting off the power fast enough once the current rises... so this is perhaps an aging problem of the non-serviceable black boxes.
I purchased the GEN II setup for my 86 from a forum member. I paid extra for him to rebuild them. I guess that didnt actually happen. The headlights have been opened / closed less than 50 times since purchasing them.
Thanks for all the info. I am gonna look for some new replacement motors.
Originally posted by pmbrunelle: I thought that Gen 2 headlights were a definitive remedy for the Gen 1 headlight woes.
No. Module is most likely doing its job and shutting off the motor for binding/jamming. Yes Module can die but much more rare of a problem then bad motors.
"Rebuilding" Gen2 motor looks simple but is not. Just the BB mention above worn to be too loose, dirt etc making it bind, DIY adjusting too loose or too tight can trip module to shut down power to that motor. Installing New Delrin pins/dowels from any vendor then the gear or output shaft can die the next time motor have problems. You have Metal gear too? Expect Output shaft death. see https://www.fiero.nl/forum/Forum2/HTML/128600.html
Fixing or "rebuild" Gen1 and Gen2 motors by DIY and many others claim can fix/rebuild cheap... can work for years or die next day. If you drive at night or in bad weather a lot then expect more problems and sooner.
Buying motors parts and messing around for hours or worse days isn't fun. Time cost money or if you don't think so, time from other things you like to do instead of fixing HL motors. Gen1 fixing/"rebuilding" just motors is bad enough. Then likely need Relay(s) too. Or replace relay(s) only to find have motor problems. Gen2 is Cheap in the long run to get New Cardone and switch in minutes and done. New ones you don't even have to deal w/ Cores Return bs. CR is bad enough locally but often a nightmare dealing web vendors.
This is why I would still upgrade to Gen2 and use Cardone motors at first sign of motor dying.
[This message has been edited by theogre (edited 12-31-2017).]
I have heard from a few people that rebuilding these is a real beach! Even then, you are just replacing the gears or "bb" and still have a 30 year old motor.
NOT my favorite place to go, as the store close to me is full of clueless people. Not the cheapest route, at $126.00 but the lifetime warranty is nice. If they ever die again, just take it back and get a new one.
[This message has been edited by JohnWPB (edited 12-31-2017).]
John, check out PartsTrain.Com or PartsGeek.Com for prices. Parts Train has the Cardone and Replacement brands, but you may have to swap the wires on the motors to get them to move in the correct direction. AutoZone, PartsTrain, PartsGeek and Stockwise all list the same motors to fit both the Firebird and Fiero and we know the Firebird motors run opposite of the Fiero. John W. Tilford is having that issue at the moment with one going up while the other goes down.
Yesterday when I looked, Parts Train was about $100 per new motor. A couple of listings was even less.
[This message has been edited by fierofool (edited 12-31-2017).]
Originally posted by JohnWPB: NOT my favorite place to go, as the store close to me is full of clueless people. Not the cheapest route, at $126.00 but the lifetime warranty is nice. If they ever die again, just take it back and get a new one.
Most other chain stores have same people working there. But AZ warranties needs only the phone # when bought the item unlike PB and others will ignore you when can't find a receipt. Worse many use thermal print receipts that fade over time or water base inks that's easy to smudged etc.
I am HORRIBLE about misplacing receipts! I buy something, and by the time I get home I have lost the receipt!
With ANY important receipt for warranties, case it doesn't fit / work ect... I open Evernote and snap a photo of it right after the purchase. Evernote reads the receipt with OCR so you can easily search for a receipt. Type "zone" and all the Autozone receipts will show up
The info is stored on your phone AND in the cloud. I have receipts and stuff from 10 years ago, and have switched phones like 8 times in that time. You can also save them to google drive if you do not want to use a specific app.
I had to stress this. I did not fix my headlights, but they work now.
After my passenger side goes down, it would often become stuck. After it closed completely, and would not rise to the occasion, I turned the knob clockwise with a bit of force. Kind of leaned on it a bit, but did not want to snap anything. Well, it now works. Has been working for the past week. I just don't know?
Is it just me or is it always the right side that gets stuck. I have two 88's and it's always the right side.
Oops never mind. First post says left side.
One thing I have discovered when rebuilding these (especially C4 motors) is that if there is not enough spacers on the side cover side of the shaft the gear can actually rub on the side cover. Especially with a aluminum or brass gear upgrade.
[This message has been edited by carguy8t8 (edited 01-06-2018).]
