  best fuel injectors
best fuel injectors by User00025831
Started on: 11-30-2017 05:27 PM
Replies: 8 (654 views)
Last post by: jmbishop on 12-17-2017 03:00 AM
User00025831
Report this Post11-30-2017 05:27 PM Click Here to See the Profile for User00025831Send a Private Message to User00025831Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All.
what is the best fuel injector brand for the 2.8?
jmbishop
Total ratings: 169
Report this Post11-30-2017 07:08 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
3800sc injectors with the rest of the 3800sc
Report this Post11-30-2017 07:25 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Clean injectors are better than dirty ones, but I have never heard of one brand being better than another.
jmbishop
Total ratings: 169
Report this Post11-30-2017 07:38 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right, injectors don't = more power unless your running out of injector or you're replacing bad ones.
If you think you have bad/dirty injectors you can send them out to be cleaned/tested.
User00025831
Report this Post11-30-2017 08:12 PM Click Here to See the Profile for User00025831Send a Private Message to User00025831Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. Much appreciated.
It's nice to have this help from so many enthusiasts.
[This message has been edited by User00025831 (edited 11-30-2017).]
unboundmo
Report this Post11-30-2017 10:50 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sent mine out as well.. RC Fuel injection .. I had them back in around three-days but they are in Cali like me.. edit to say-- you're close too.. just noticed. They are in Torrance ..---- check them out though. A Print-out came back with it and explained what was going on.. if anything.. flow percentages of how they performed before and after.
https://www.rceng.com
[This message has been edited by unboundmo (edited 12-01-2017).]
User00025831
Report this Post12-16-2017 11:07 PM Click Here to See the Profile for User00025831Send a Private Message to User00025831Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the heads up in So Cal. i will bookmark these guys.
From Riverside moving to Upland.
Harold James Kie
Report this Post12-16-2017 11:35 PM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
One option is to purchase a ultra-sonic cleaner and clean them at home. You can get a cleaner from Harbor Freight for under $75. I don't know what a auto/diesel shop would charge but if it is a reoccurring issue it might be worth it. You can always find other uses for it as well. My injectors were stuck from setting for many years and I cleaned them myself in a ultra-sonic cleaner that I bought used. You will have to do a bit of research to find the right fluid to use as there are a lot of options and opinions.
jmbishop
Total ratings: 169
Report this Post12-17-2017 03:00 AM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
A ultrasonic cleaner is great to have but the piece of mind of having them tested is usually worth sending them out. You can test them yourself, you'll be able to see the spray pattern but measuring the flow would take a little effort.
