  Humble Brag
Humble Brag by KMFDMFAN
Started on: 07-25-2017 10:35 AM
Replies: 8 (334 views)
Last post by: KMFDMFAN on 07-26-2017 01:54 PM
KMFDMFAN
Report this Post07-25-2017 10:35 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a small feather in my cap for that one time Hot Rod Magazine put a photo of my 88 GT in an online article for the 2016 HOT ROD POWER TOUR
... of other note it was in an article titled "The Odd, Orphans, Freaks and Four Doors."
http://www.hotrod.com/artic...wer-tour-white-coupe
Mine is photo 94 0f 98
Report this Post07-25-2017 12:35 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome, that doesn't happen often with Hotrod
Total ratings: 461
Report this Post07-25-2017 06:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool! And you're in some good company, too.
Shho13
Report this Post07-25-2017 11:05 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice 88... Congrats on the pic!
Do you have the lowering ball joints in the front from Rodney or did you lower by cutting the springs? It looks great at that height!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Total ratings: 466
Report this Post07-26-2017 01:41 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by KMFDMFAN:
Just a small feather in my cap...
And here I thought this thread was going to be about your mastery of PIP.
KMFDMFAN
Report this Post07-26-2017 10:00 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like to think we all are.
KMFDMFAN
Report this Post07-26-2017 10:08 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
KMFDMFAN
Member since Sep 2013
Thanks! :-D
I didn't like how the 88's seem to ride higher in the front so...
I got an extra set of springs from The Mall and just cut one coil off. All at the same time I swapped out for all poly too.
The rear is almost all poly too. KYB shocks/struts all around. Amazing what just cleaning/refurbishing your suspension can do for squeaks, creaks, and rattles... until I have to soak the poly bushings with silicone once a year.
[This message has been edited by KMFDMFAN (edited 07-26-2017).]
Report this Post07-26-2017 12:30 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you do this while they are still installed, and what do you use?
KMFDMFAN
Report this Post07-26-2017 01:54 PM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
I slathered them with the original Teflon grease that came with the poly bushing when I first installed them but that was a few years ago. Maybe it wasn't enough...
Since then (and a LOT recently) rain and splashing through unavoidable puddles must've washed some off. Once when I had the wheels off doing brake work I sprayed Liquid Wrench Silicone Spray around the exposed parts of the bushings.
Another time after a recent deluge the front started squeaking. So I turned the wheels back and forth to full lock and sprayed again. That was over a month ago and hasn't made a chirp.
I hope silicone spry isn't bad for polyurethane!?
