  Last races of the season
Last races of the season by lou_dias
Started on: 10-23-2016 10:46 PM
Replies: 10 (255 views)
Last post by: lou_dias on 10-26-2016 08:59 AM
lou_dias
Report this Post10-23-2016 10:46 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree
Total ratings: 350
Report this Post10-24-2016 12:08 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Needs more Camaros.
lou_dias
Report this Post10-24-2016 01:11 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those old Camaros are smoking those new Vettes'...
I ended up in 4th place in points overall. The black Camaro, silver Camaro and WRX finished 1,2 and 3 respectively overall. We raced around 15 times in total starting back in May.
Blacktree
Total ratings: 350
Report this Post10-24-2016 11:10 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That black Camaro looks like it's dialed-in really well... good driver also. Unless my eyes deceive me, it looks like he weight-jacked the suspension for left turns. It doesn't look like any of the other cars have that.
lou_dias
Report this Post10-24-2016 12:40 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah he's totally set up. He's not technically the fastest car there but he's pretty consistent. I almost beat him in May until I lost camber and toe on my back left wheel and did a 180 infront of the start/finish line. He ended up being the overall points leader.
Report this Post10-25-2016 08:32 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by lou_dias:
I almost beat him in May until I lost camber and toe on my back left wheel and did a 180 infront of the start/finish line. .
Problem keeping bolts tight?
lou_dias
Report this Post10-25-2016 10:07 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Seems good now...finally.
Report this Post10-25-2016 09:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ended up in 4th place in points overal...
Did it surprise you that the old pickup truck gave you such a good run for your money in the 1st round?
What is used as a cue to start each race? Some of the guys are either asleep at the switch... or the other guy has jumped the gun!
And finally... how is it decided who lines up where on the track? I've never raced on a banked oval, but I suspect I'd want to start on the inside lane.
[This message has been edited by Patrick (edited 10-25-2016).]
cvxjet
Report this Post10-25-2016 10:17 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
At least on my 85 with 88 rear, I end up all the way in at the top on both sides for camber....I am planning on installing small steel "eyebrows" to fill the adjustment gap to keep it from moving, trapping them under the washers....Just an idea.....The other possibility would be custom washers that set the adjustment, permanently....
lou_dias
Report this Post10-26-2016 08:55 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
About the truck. No. He's a regular and we all know what we are running. All the hoods are up for inspection prior to the race. He's got a built big block. Traction at the launch is his weakness. His suspension is custom. The bed is missing and you can see all his custom work. Very talented guy. He recently added some weight directly over the rear axle to help with the launch. The officials asked the rest of us if we had issues with it and we all said no problem.
A coin toss in the infield determines who lines up inside or out.
There's a red and green light infront of the start/finish line. When it turns green you go.
So cars are slow off the line because they are "stock"-ish. You're allow 100 treadwear rated tires. Pretty easy to figure out who has them and who doesn't.
lou_dias
Report this Post10-26-2016 08:59 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
Hopefully I am good from now on.
I just need to make my back right strut softer. Had wheel-hop there in my final race against the WRX. Slid right to the outside...
