  Dashboard lights
Dashboard lights by 85fieroguy
Started on: 09-27-2016 10:16 AM
Replies: 19 (1627 views)
Last post by: 2.5 on 09-29-2016 08:47 AM
85fieroguy
Report this Post09-27-2016 10:16 AM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guess the eyes are going. Can't see much at night with the stock bulbs. Are there brighter plug in replacements???. Not looking forward in pulling the dash so I want to do it right. What is better for color ?? Red, orange or white ??
Report this Post09-27-2016 11:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might be an obvious question... but is the dimmer functional and adjusted to the brightest setting?
[This message has been edited by Patrick (edited 09-27-2016).]
Report this Post09-27-2016 11:58 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
OE bulbs/sockets could be bad or old or very likely dimmer have problems.
See my Cave, Dash Dimmer and maybe Lighbulbs
see Instrument panel bulb layout (covers color change)
Change color can have problems. better/worse depends exact color etc of bulb/led and which dash used.
(Image server seem to be down right now so might not be able to view most of them.)
Note: OE dimmer often have problems with many LEDs and is a crap shoot buying LED for this use. Even when you buy exact same part that works for others. Any minor issue w/ the dimmer circuit may be ok w/ normal bulbs can hate many LED.
jscott1
Total ratings: 415
Report this Post09-28-2016 01:47 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
It seems that 99.999% of Fieros have dim dashes at this point but I have yet to hear a definitive cause and definitive solution.
I've read Theogre's write-up and it still leaves me scratching my head. Is it the dimmer? Is it the transistor? The bulb sockets? Why can't we have a fix out there that is guaranteed to work 100% of the time?
TopNotch
Total ratings: 60
Report this Post09-28-2016 08:01 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my car, it was the transistor socket, and I used this fix.
trivet
Report this Post09-28-2016 08:39 AM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced all of my dash lights with LEDs, HUGE difference. Bright, clear, looks like a new dash. Got them on Amazon for about $12.
I used red LEDs', and it looks incredible. One of the best and cheapest "upgrades" I've done. No more dim dash lights, MUCH more modern looking, very similar to the dash lights in my 2006 Torrent (ok, maybe a 10 year old SUV isn't "modern", but its 19 years newer than my Fiero )
85fieroguy
Report this Post09-28-2016 11:29 AM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Everything in the system is ok EXCEPT under certain city lights, I can't see much..its always been that way. TRIVET..what company did you get the LED from on Amazon ???
trivet
Report this Post09-28-2016 12:34 PM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Partsam 6PCS T10 PC168 Wedge Instrument Panel LED Light Gauge Cluster Lamp with Twist Lock
Link is here
Tim
85fieroguy
Report this Post09-28-2016 12:37 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tim..thanks..your the greatest !!!
85fieroguy
Report this Post09-28-2016 12:50 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
85fieroguy
Member since Aug 2015
Can the T-10 PC 168 LEDs be also used else where like on the side markers, interior etc. ???? Thanks Tim
Report this Post09-28-2016 01:21 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jscott1:
1. It seems that 99.999% of Fieros have dim dashes at this point but I have yet to hear a definitive cause and definitive solution.
2. I've read Theogre's write-up and it still leaves me scratching my head. Is it the dimmer? Is it the transistor? The bulb sockets? Why can't we have a fix out there that is guaranteed to work 100% of the time?
1. Not that bad but you only hear about problems.
2. Because could be any or all making dim lights.
Some has X, other Y, yet Others Z, and some have XY, YZ, XZ or all three.
I've seen "dead/dim" bulb and socket caused by heat/pressure deformed plastic sockets, dash case and circuit board. Rotate the socket a bit to makes a better connection and works after.
More confusing, Can be little to nothing wrong w/ the dash but have power/ground problems anywhere in the car causing low volts etc.
Example: I went thru the car and clean/fix all ground points to prevent problems. Many in the bay and front had rust and corrosion causing loose screws etc. Iffy grounds in the cabin can kill power windows and even the fuel pump.
These problems are not unique to Fiero. Many GM cars and others use same way to dim but even simple power rheostats use by Ford GM etc earlier had most of same problems. Many may remember turning HL switch to dim the dash. These had wire nichrome rheostats and did get warm to hot to touch as normal operation.
Example: Ford Pinto and others HL switch and dash dimmer. Rheostat is ceramic and nichrome and sees full load of all bulbs to dim.
Some old cars, before '80s, had separate dimmers but are using same method to dim the dash.
Note: Instrument panel bulb layout link, PIP picture server is back today
JohnWPB
Total ratings: 144
Report this Post09-28-2016 04:12 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a word of warning; If you replace them with LED's, make sure to test them before reassembling the cluster! LED's need to have negative to negative and power to power. If you just stick em all in randomly, you will have about 50% of them not working. This is especially a pain with the dummy lights. Either follow the ground going to each one, or use a test probe to test em.
trivet
Report this Post09-28-2016 04:51 PM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent point - very glad you mentioned it, as I had that exact issue myself (only about half worked when I tried them, luckily I hadn't reassembled anything yet)
I only changed the dash illumination bulbs, left the "idiot lights" and turn signal indicators alone. Not sure if the LEDs work with them anyway, and I wasn't concerned about how bright THEY were,
Report this Post09-28-2016 06:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just as well...
most Id10t light don't need bright bulbs or LED.
Alt light need correct resistance to make the old SI and some CS alt's to turn on. (Most CS for factory install use another wire to turn on when light is blown.)
Bright High Beam and others light can/will annoy many. Even 194 bulb to light them is bad to many driving at night.
Report this Post09-28-2016 06:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is sort of related... After my '86 GT has been started, why do I need to rev the engine once before the alternator starts to charge? The charging light bulb works, and the alternator charges the battery fine... after it's been "excited" by the engine being revved once.
I don't want to throw this thread off on a tangent, but I'm hoping there's a short simple answer.
Report this Post09-28-2016 07:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong or "bad" regulator can to this.
Wrong if alt is setup to be a "1 wire" alt, often bought thru Summit Ebay and others.
Could be iffy reg, diode(s), etc, so take alt out then to store for testing.
Could be "power pulleys" making alt spin too slow when start the engine.
Report this Post09-28-2016 08:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...take alt out then to store for testing.
This '86 GT is an automatic ... so taking that alternator out for testing purposes would be one of the last things I'd do. For now I'm content to rev the motor once to "excite" the alternator.
Thanks for the suggestions though, Ogre.
[This message has been edited by Patrick (edited 09-28-2016).]
85fieroguy
Report this Post09-28-2016 10:40 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Geees Patrick..from watching your posts..I thought you were bullet prove with NEVER having any Fiero problems. LOL..kidding
Report this Post09-28-2016 11:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn, they're old cars... there's always something to repair or maintain.
Report this Post09-29-2016 08:47 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any place a 168 / 194 is used.
