  Severl years away from the fieros.. now I'm back.. was it a mistake? Lol
Severl years away from the fieros.. now I'm back.. was it a mistake? Lol by jessesmith121
Started on: 04-10-2016 03:14 PM
Replies: 9 (277 views)
Last post by: ltlfrari on 04-11-2016 10:33 AM
jessesmith121
Report this Post04-10-2016 03:14 PM Click Here to See the Profile for jessesmith121Send a Private Message to jessesmith121Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well my ex wife made me ditch my last fiero... a super sweet 86 gt with all the trimmings. Now a year after my divorce I picked up a 87 gt 5 speed. The interior is sweet and it's in great shape. The PO said it stopped running on the highway. So I'm chasing that down. It's been a Pain in the ass so far. Next in changing computers and checking Valve lash and ensuring I'm timed TDC with cylinder #1. I just want to drive this beast... I guess it will make it all worth it in the end, right?
IMSA GT
Total ratings: 250
Report this Post04-10-2016 03:27 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sometimes just the divorce alone makes everything worth it......and better.
jessesmith121
Report this Post04-10-2016 03:51 PM Click Here to See the Profile for jessesmith121Send a Private Message to jessesmith121Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you know why divorce is so expensive?......... Cuz it's worth it...lol
Report this Post04-10-2016 03:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what the symptoms are with your GT or what you've checked, but do you have spark? It's not uncommon for the ICM to fail.
jessesmith121
Report this Post04-10-2016 04:45 PM Click Here to See the Profile for jessesmith121Send a Private Message to jessesmith121Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've replaced the distributor and all the stuff with it.. and the coil.. im going to ensure I'm TDC with cylinder 1 next. Then the computer, then inspect valve lash...
Alex4mula
Report this Post04-10-2016 04:54 PM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spark, fuel, timing then the rest. I have seen new modules not working. Doubt it is ECM. Check the basics first. If PO is correct then it should be module, pick-up coil or fuel pump. Good luck!
jessesmith121
Report this Post04-10-2016 05:13 PM Click Here to See the Profile for jessesmith121Send a Private Message to jessesmith121Edit/Delete MessageReply w/QuoteDirect Link to This Post
It has to be with spark or timing. It won't fire with starting fluid either.
Report this Post04-10-2016 06:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Valve lash needing adjustment isn't going to prevent the engine from starting.
Make sure you're on TDC of #1 on the compression stroke... and don't assume the timing mark on your balancer is correct. The outer hub can spin when the balancer starts to fail.
IMSA/GT
Report this Post04-10-2016 07:03 PM Click Here to See the Profile for IMSA/GTSend a Private Message to IMSA/GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine quit on the highway too. Found that a cracked crossover pipe overheated the ICM. Once it cooled down then the car would start normal again. Replaced the xover pipe and no problems since.
[This message has been edited by IMSA/GT (edited 04-10-2016).]
ltlfrari
Total ratings: 127
Report this Post04-11-2016 10:33 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to say ignition module but since you've replaced the dizzy I guess you replaced that as well.
Are you getting a spark at all? Pull plug and rest on engine while turning over.
If not then any power to coils, ignition module. If I remember correctly, it 'should' at least spark even without an ecm because it should be in bypass mode until around 400 rpm at t which point the computer/im takes over.
Fuses?
Dave
www.ltlfrari.com
