  Best Lowering springs? (Page 1)
Best Lowering springs? by Burly1
Started on: 04-05-2016 08:02 PM
Replies: 40 (4200 views)
Last post by: fieroguru on 04-12-2016 08:38 PM
Burly1
Report this Post04-05-2016 08:02 PM Click Here to See the Profile for Burly1Send a Private Message to Burly1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking at lowering my Fiero to eliminate some body roll and for the look as well. It's an 88 2.5 5 speed. Everything I have found has been for 84-87s, besides the fiero store springs. I do participate in a little autocross so it has to be functional. Thanks.
Total ratings: 205
Report this Post04-06-2016 09:20 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMHO, the best option for lowering springs on an 88 is to cut the existing stock springs.
GM reduced the spring rate on the 88, most lowering spring are in the 300# range, way too stiff for an 88. Cut stock springs only increase spring rate slightly, maybe 20%.
One coil on each corner has worked well.
Addition of the rear anti-roll bar from a GT or Formula will make a significant improvement.
Check out fieroguru's lateral link relocation brackerty as well to improve rear camber characteristics.
IanT720
Report this Post04-06-2016 09:34 AM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly! I'm not to sure about 88's since I haven't owned one. But if springs are hard to find, just chop off a coil. I've done it a bunch with many cars. The ride is just stiffer, but works perfect. On my 87 I got some ST springs cheap, so I went that route. ST are the lowest springs you can buy.
Report this Post04-06-2016 01:22 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Formula rear sway bar isn't up to par?
Total ratings: 458
Report this Post04-06-2016 02:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of info in this thread - Lowering an 88 Formula ???
I won't bother repeating what I already stated in that thread. I will add though that I removed the front lowering springs and replaced them with the stiffest '84 front springs with two coils removed. I'm very pleased with how they feel at autocross. The rear lowering springs are alright, but I'd now like the back of my Formula to be an inch or so lower. The next change might be to adjustable rear coil-overs.
Cutting the front springs works well on a Fiero to lower it... but because of the shape of the rear springs and how they mount/sit, IMO cutting them down doesn't work as well.
Total ratings: 458
Report this Post04-06-2016 02:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
I suspect you've misunderstood what was posted. There is no factory sway bar on the back of an '88 coupe. The suggestion made (and it's a good one) is to install a rear sway bar from an '88 GT or Formula.
[This message has been edited by Patrick (edited 04-06-2016).]
Report this Post04-06-2016 03:37 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wups yep, I read the statement as to put a GT one on a Formula. oops.
Thanks
Burly1
Report this Post04-06-2016 06:03 PM Click Here to See the Profile for Burly1Send a Private Message to Burly1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies.
Sounds like I will be looking at getting a swaybar.
Although cutting springs seems to be the way to go I'm not too into the idea of cut springs.
Has anyone had experience with the West Coast Fieros coilovers and front springs kit?
A stiff ride doesn't scare me away much.
Total ratings: 458
Report this Post04-06-2016 06:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just curious... What is your apprehension in doing so?
Burly1
Report this Post04-06-2016 06:16 PM Click Here to See the Profile for Burly1Send a Private Message to Burly1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just would rather do it the right way the first time. I can't help but correlate cutting springs with "slammed" Honda Civic's for some reason.
Total ratings: 458
Report this Post04-06-2016 06:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...which translates to you believing that using springs which have been shortened by having a coil or two cut off is the wrong way to lower a car.
You realize of course that coil springs don't spontaneously appear at a prescribed length. They're CUT to length from much longer lengths of steel before being formed.
I just think you're cheating yourself of possibly creating something that will perform exactly the way you want... for no valid reason.
Burly1
Report this Post04-06-2016 07:21 PM Click Here to See the Profile for Burly1Send a Private Message to Burly1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Partially I don't want to mess anything up either. There's a lot more opportunity for error when cutting the spring versus buying different ones. If I mess up my stock springs i'll have to source a new set.
Total ratings: 458
Report this Post04-06-2016 07:29 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never suggested you cut your stock '88 springs.
Burly1
Report this Post04-06-2016 07:37 PM Click Here to See the Profile for Burly1Send a Private Message to Burly1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just don't like the idea of cut springs in general
Total ratings: 458
Report this Post04-06-2016 07:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fine.
Total ratings: 205
Report this Post04-06-2016 09:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you use too stiff a lowering spring on an 88 (and for the street, most offering are way too stiff) you end up with a car that handles like a tiddly wink on rough surfaces.
Fine for a racetrack, but on the street they can be dangerous.
Been there, done that, have the T-shirt.
Cut the springs with a hacksaw or die grinder, e-z p-z, no brainier type thing.....
tebailey
Report this Post04-06-2016 09:28 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed, NEVER USE A TORCH! The heat from a torch cut will destroy the temper in the springs. I cut my 84's fronts one coil and it lowered the front a little over an inch and once I cut the stop tower down the ride is not much stiffer than before.
hnthomps
Total ratings: 51
Report this Post04-06-2016 09:30 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depending on how far you want to lower the vehicle, you could use rear coilovers and Rodney Dickman's lowering ball joints (0.5" and 1.0"). I have coilovers and one inch lowering ball joints on an 88 and like the stance very much.
Nelson
Total ratings: 460
Report this Post04-07-2016 06:00 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have experimented with cut springs on several 88s.
Removing one coil will lower the front to match the stock rear height.
On my 88, I currently have 86 GT springs in the front, cut by 1.25 coils. In the rear, I have 88 front springs, cut down by ~1 coil.
This increases the spring rate on all 4 corners, but not by much.
As long as you use a cutoff wheel to cut the springs (do NOT use a torch) you should have no issues. After I make the cut, I dress the end with a file, then paint to prevent oxidation.
I'm about to rebuild the entire suspension on an 88 that I just bought. Full poly. Monroe Sensatracs.
The front springs will be cut by one coil. The rears will likely remain stock. Otherwise, no changes for now.
[This message has been edited by Raydar (edited 04-07-2016).]
IanT720
Report this Post04-07-2016 05:53 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Never use a torch. I've used an angle grinder many times. Works great! I don't slam them, just lower a bit. Looks way better.
Report this Post04-08-2016 10:07 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does it increase the spring rate less than cutting one coil off of 88 fronts and leaving them in front?
Also does it leave it the same height as just cutting 1 coil off the front of 88 fronts (thus matching the rear)?
Thanks
Total ratings: 205
Report this Post04-08-2016 12:46 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spring rate is higher on the pre-88's, so 2 coils from an 86 spring would give a higher rate than 1 coil off of an 88 spring.
dobey
Total ratings: 371
Report this Post04-08-2016 01:06 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drop spindles.
Lowering ball joints.
carbon
Total ratings: 132
Report this Post04-08-2016 03:25 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
All stock '88 suspension, Rodney Dickman's 1" drop front lower ball joints.
[This message has been edited by carbon (edited 04-08-2016).]
Total ratings: 458
Report this Post04-08-2016 04:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
For anyone who's only interested in bringing the '88 front end down (to where it should've been from the factory), that method seems to work out very well.
However, if the whole car is to be lowered and/or it's desired for the suspension to be a little stiffer (for autocross etc), the choices become less clear.
carbon
Total ratings: 132
Report this Post04-08-2016 05:03 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup... just giving the example. OP said he doesn't like cutting springs, so here's the example. Sometimes it helps to know the difference individual components make.
Missing where I said I was [/end]ing the thread.
Total ratings: 458
Report this Post04-08-2016 05:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 132
Report this Post04-08-2016 05:13 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You responded as if I hadn't read the rest of the thread or somehow thought this was all one would need to lower the car.
Obviously front ball joints won't affect the rear right height. Just showing the effect of the one mod vs. laundry list + picture.
Edit: Yeah prolly reading too much into this like everyone does around here... just trying to fit in again...
Total ratings: 458
Report this Post04-08-2016 07:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man oh man, I gave your post a thumbs up and also stated... "that method seems to work out very well".
You're correct, you read far too much into what I had posted. You possibly need to remind yourself that the OP (and other newbies) reading this thread probably don't know what you and I might know, and it doesn't hurt to re-consolidate what's being said. Geez...
[This message has been edited by Patrick (edited 04-08-2016).]
carbon
Total ratings: 132
Report this Post04-08-2016 10:21 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tee hee, well that was fun... just messin' with you Patrick.
Have a good one!
Total ratings: 458
Report this Post04-09-2016 03:39 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No problem... meet my friend.
Report this Post04-11-2016 11:00 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
No other changes required? Seems like a nice choice.
carbon
Total ratings: 132
Report this Post04-11-2016 02:24 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To the OP's use case, I wouldn't recommend the lowering ball joints on a car that would be autocrossed... it puts more strain in the lower control arm and/or ball joint than what it was probably originally designed to handle. For me it's not really a big deal, but really biting into a corner would make me worry a little bit.
They give the steering knuckle a good additional bit of leverage on the LCA and ball joint itself. Some people have welded them in, I have not and didn't have a problem for the 3 years I drove it before parking it.
Imnuts
Report this Post04-11-2016 03:16 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the front of my 88 with Rodney Dickman's 1" drop front lower ball joints. Does yours measure 27"?
Total ratings: 458
Report this Post04-11-2016 04:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That measurement would mean a whole lot more if you also mentioned your tire size/diameter.
Imnuts
Report this Post04-11-2016 04:13 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think they are stock 205/60 15.
Total ratings: 458
Report this Post04-11-2016 04:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Figured I may as well show what the current stance (with 225/50/16 tires) looks like with my Formula.
And just out of curiosity, I measured the distance from the road to the top of the front fender opening. It was 25.5 inches. The back is 26.5 inches.
[This message has been edited by Patrick (edited 04-11-2016).]
carbon
Total ratings: 132
Report this Post04-11-2016 04:50 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went out and measured mine at 26.5"... so pretty close. With as soft as the 88 front springs are, it doesn't take much weight to change the settled ride height.
[This message has been edited by carbon (edited 04-11-2016).]
Ryanap333
Report this Post04-11-2016 09:11 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got the fiwro stores suspension kit 2 with the lowering sprungs shocks and swaybars for my 87 328 replica. Got the back on now. Im in the middle of a 3800sc swap and thats how its sitting right this minute. I will say that i like the looks of the new stance
Blacktree
Total ratings: 350
Report this Post04-12-2016 12:35 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
My '87 Fiero has an '88 cradle swapped in, with 350 lb/in coilover springs. It doesn't feel too stiff in the back. Actually, it rides smoother than the '87 rear suspension did with Eibach springs. My first impression after swapping in the '88 cradle and suspension was "Hey, the rear end doesn't skitter like a go-kart anymore!"
That said, cutting the springs is a viable alternative, if done properly. Don't cut them with a torch, and don't heat the end with a torch to bend it. That will ruin the temper of the steel. Instead, cut them with an angle grinder or something similar, and drape a wet rag on the spring to help keep it from getting too hot. Just don't snag the wet rag with your angle grinder, that would suck.
