  Need to replace rusty 87 GT Distributor, Question ?
Need to replace rusty 87 GT Distributor, Question ? by robert1234
Started on: 03-26-2016 10:01 PM
Replies: 12 (449 views)
Last post by: Patrick on 03-28-2016 08:06 PM
robert1234
Report this Post03-26-2016 10:01 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is the Cardone 84-1633 or the WAI DST1633 better?
What are the issues with both? I saw something about melting ?
Can someone explain, I want to replace mine since its rusty.
Thanks
Total ratings: 463
Report this Post03-27-2016 01:32 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little bit of rust never hurt nuttin.
Umm... is the inside of the distributor supposed to look like this?
Originally posted by Patrick:
robert1234
Report this Post03-27-2016 05:25 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, its not that bad. But does not look good.
You think it will be ok?
Thunderstruck GT
Total ratings: 99
Report this Post03-27-2016 05:51 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
MSD distributors get rusty all the time and the shaft will seize.... It's a common issue.
No one is throwing them out at what they cost.
Like the MSD unit, take it apart, clean it up and lube it.
Total ratings: 463
Report this Post03-27-2016 06:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so you know... that same distributor I pictured above was eventually transplanted (after it was cleaned up a bit ) into my '88 Formula which I daily-drive and autocross, and it works just fine.
[This message has been edited by Patrick (edited 03-27-2016).]
robert1234
Report this Post03-27-2016 07:44 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great info, I'll pull it and clean it up.
It works just fine, since everything is original, its rusty over the years.
Thanks
Total ratings: 463
Report this Post03-27-2016 08:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...its rusty over the years.
Apparently the reason why the inside of the distributor rusts so bad is because ozone is produced inside the distributor (from the spark jumping to the poles in the cap from the rotor) and this heavily contributes to the corrosion... so make sure the wire mesh screen (for ventilation) in the base of the distributor is free of debris.
Thunderstruck GT
Total ratings: 99
Report this Post03-27-2016 08:20 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
No
It's rusty over the parts.
Thunderstruck GT
Total ratings: 99
Report this Post03-27-2016 08:28 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thunderstruck GT
Member since Oct 2015
robert1234
Report this Post03-28-2016 07:39 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pat, you are correct. And with every spark, small pieces of metal are blown away with very high heat and very high current for nano / micro seconds
It also produces alot of RF
robert1234
Report this Post03-28-2016 07:40 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
robert1234
Really, Not Bill Nye !
LOL
Thunderstruck GT
Total ratings: 99
Report this Post03-28-2016 07:51 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL
LOL!
Bill "Patrick" Nye
Total ratings: 463
Report this Post03-28-2016 08:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't wear bow ties.
