  Passenger Side Turn Signal Problem, Front and Front/Side
Passenger Side Turn Signal Problem, Front and Front/Side by DKcustoms
Started on: 02-01-2016 07:47 PM
Replies: 11 (219 views)
Last post by: theogre on 02-04-2016 02:09 PM
DKcustoms
Report this Post02-01-2016 07:47 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I searched for anyone else having this issue, but was unable to find anything similar that worked.
Car is an 88 Formula, but has a 87 front wiring harness as I "believe" the original harness had the same issue.
I have LED switchbacks in the front bumper lights that run white with the driving lights and amber with the turns.
The problem is that both the turn signals for the passenger side are not working (I switched the bulbs from the other side and the same doesn't work, so its not the bulbs)
Once again, I "believe" the original harness had the same issue, but I could be wrong, I switched the harnesses over the summer when I tore the car down to the frame.
I think the idea was to fix this same problem, but at this time I don't remember.
I just got power back to the car the other day so I am rediscovering the issue.
I thought about trying to put a new socket on the front turn signal to see if that fixes the problem, but I don't know if that explains why the side signal isn't working either.
The fender grounds are in place on both sides, horn works, etc.
Any ideas other that me trying to solder on a new turn signal socket?
tshark
Total ratings: 64
Report this Post02-01-2016 07:52 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the bulbs in the side marker lights and the turn indicators in the instrument cluster. Is the issue thar the lights don't illuminate, or that they don't blink?
Shade Tree Fiero
Report this Post02-01-2016 08:16 PM Click Here to See the Profile for Shade Tree FieroSend a Private Message to Shade Tree FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem on a 88 gt it was the plug on the turn signal stalk on the steering column
DKcustoms
Report this Post02-01-2016 09:01 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
All the bulbs work, both in the instrument cluster and the exterior markers themselves.
The issue seems to be the the exterior lights are not getting the power/signal to flash
Can you elaborate on this?
Shade Tree Fiero
Report this Post02-03-2016 05:44 PM Click Here to See the Profile for Shade Tree FieroSend a Private Message to Shade Tree FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
you have a pm
Shho13
Report this Post02-03-2016 07:16 PM Click Here to See the Profile for Shho13Click Here to Email Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check the grounds on the bulb sockets. Fairly common issue.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
88FieroGT TTops
Report this Post02-03-2016 10:27 PM Click Here to See the Profile for 88FieroGT TTopsClick Here to Email 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
aren't you supposed to replace the flasher?
Pat Jones
84fiero123
Total ratings: 325
Report this Post02-04-2016 12:13 AM Click Here to See the Profile for 84fiero123Click Here to Email 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You did change the blinker fluid right?
Steve
DKcustoms
Report this Post02-04-2016 12:17 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did do this, forgot to add that, because I did doublec4's led taillight kit
DKcustoms
Report this Post02-04-2016 12:18 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
DKcustoms
Member since Oct 2013
sockets themselves are free of corrosion, PO used plenty of electrical grease.
viperine
Report this Post02-04-2016 12:57 AM Click Here to See the Profile for viperineClick Here to Email viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second the grounds. I had one side that wouldn't flash, the ground wire at the front of the bumper turn signal was broken, but appeared just fine until I really yanked on it. Long story. But, as for the flasher units. Did you replace both flashers? And if so, did you use a flasher intended for LED's?
[This message has been edited by viperine (edited 02-04-2016).]
Total ratings: 551
Report this Post02-04-2016 02:09 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace w/ normal bulb to check the socket etc.
Leave socket out to see the filaments.
Park = dim filament only
Turn = bright filament only
Both filaments on for each function is ground problem.
Ground problems often cause Sneak Path ground w/ normal bulbs too.
