  It's good to be back
It's good to be back by SCRebeck
Started on: 01-22-2016 10:55 AM
Replies: 8 (269 views)
Last post by: Raydar on 01-23-2016 12:31 PM
SCRebeck
Report this Post01-22-2016 10:55 AM Click Here to See the Profile for SCRebeckSend a Private Message to SCRebeckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone. It's been a long time since I've been on here, since I sold my fiero (85 SE). Horrible mistake. It's been eating away at me for 2+ years so I finally bought a new one. This time an 86 GT. It's in fair condition, body is excellent. Paint is faded, fuel and temp guages are wonky, shifter is sloppy, and it has a horrible exhaust leak, but it has all the options I wanted like A/C and sunroof. First thing I need to do if fix the exhaust leak, however there are several manifold bolts snapped off in the heads. I need to figure out how to fix it without dropping the cradle, since I don't have an engine hoist. Anyway just thought I'd make a post.
Pics:
http://imgur.com/a/lBiMQ
[This message has been edited by SCRebeck (edited 01-23-2016).]
Report this Post01-22-2016 04:58 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome back! You may want to reduce your photo size a bit.
notwohorns
Report this Post01-22-2016 07:25 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome back and I hope you have fun with it
Total ratings: 463
Report this Post01-22-2016 08:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, it's pretty difficult viewing an image 4096 pixels wide on a screen running 1920x1080 resolution.
If you're running Windows, use PIP to post your images. They can be no wider than 1024 pixels, and the file size can be no larger than 300 kb.
zzzhuh
Report this Post01-22-2016 11:00 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Resized picture:
Welcome back!
SCRebeck
Report this Post01-23-2016 03:21 AM Click Here to See the Profile for SCRebeckSend a Private Message to SCRebeckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks zzzhuh! I'm posting via mobile so I its a little difficult.
Jfrost
Report this Post01-23-2016 09:37 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome back!
I had a few manifold bolts break off and had to remove the engine/cradle to have enough room to drill them out. If you have a compact enough drill you can likely get the rear bolts out, but I'd be nervous about having the drill bit aligned properly with the limited access. Good luck!
Project L67 Fiero
SCRebeck
Report this Post01-23-2016 10:41 AM Click Here to See the Profile for SCRebeckSend a Private Message to SCRebeckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Jfrost:
Welcome back!
Yesterday I was poking around under the car and noticed a crack in the forward facing exhaust manifold, so I drilled holes at the ends to stop it from spreading and then used "quicksteel" to patch it. Kind of a quick and dirty fix but I figured it was worth a shot. Now there's no noticeable leak even under a load! Quicksteel is interesting stuff. I'm not saying that I wont eventually have to drop it and fix those studs, but I was pretty surprised you can't hear a leak with broken studs. Now my priority is to figure out why my idle is suddenly high after putting in some new sensors :/
Total ratings: 463
Report this Post01-23-2016 12:31 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome back to the obsession!
A high idle is likely a vacuum leak. The most likely culprit is a cracked or broken EGR tube. Goes from the EGR valve to the underside of the upper intake, at the end of the throttle neck. You won't be able to see the crack, due to the wrapping that's around it.
