  flairing the ends of fuel sending unit?
flairing the ends of fuel sending unit? by rcp builders
Started on: 01-03-2016 08:39 AM
Replies: 1 (145 views)
Last post by: Dennis LaGrua on 01-03-2016 08:48 PM
rcp builders
Report this Post01-03-2016 08:39 AM Click Here to See the Profile for rcp buildersSend a Private Message to rcp buildersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was wondering if anyone has upgraded their fuel lines by cutting and flairing the ends of the sending unit?
I would like to do away with any rubber hose on my sbc swap and go with AN fittings and braided lines.
perhaps there is another GM sender of the same size already fitted this way? Thank you, Ray
Report this Post01-03-2016 08:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by rcp builders:
Was wondering if anyone has upgraded their fuel lines by cutting and flaring the ends of the sending unit?
Russell makes a connector that should clip to the fuel line. Another method is to cut the line, put a flare nut w fitting on the tube and use a 30* AN flaring tool to make the flare to fit to the #8 AN male braided hose end.
