  Headlight lids
Headlight lids by Ryanap333
Started on: 01-01-2016 06:39 PM
Replies: 6 (259 views)
Last post by: Ryanap333 on 01-02-2016 06:31 PM
Ryanap333
Report this Post01-01-2016 06:39 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
My fiero chassis 328 replicas headlight lids pop up at about 75mph. The hood has the vents on it but they are just for looks and have no actual openings for ventalation behind the headlights or atop the radiator to vent. I seen somewhere people were cutting out holes in the like wheel wells to vent the air pressure that forces the lids open. Any ideas? Also Timm Bacher aka phonedawgz, aka red devil river sucks. He stole my harness and ecu. My bank gave me back the $200 deposit he didnt refund. Hes a total crook.
[This message has been edited by Ryanap333 (edited 01-01-2016).]
Khw
Total ratings: 134
Report this Post01-01-2016 06:58 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
On Fierosounds site about 1 of his Fieros he shows where he installed 2 vents in the front bay for that reason. It's down the page a little.
http://www.fierosound.com/moreMODS.htm
I didn't read it right now but if I remember correctly he found a different spot on each side as the front bay isn't perfectly symmetrical. Then he bought a couple grilles and installed them over the holes he cut to vent the air pressure. Pretty unobtrusive way to go about it. Me, I did the vent over the radiator in the hood when I had mine. Either works it's just dependent on what kind of final look your going for with your Fiero.
[This message has been edited by Khw (edited 01-01-2016).]
Report this Post01-02-2016 12:19 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
HL door popped at 70mph then door or front has problems.
Popping doors happens > 90+, most times > 100mph or more.
Door should have 2 spring to hold them down. One can break or is missing.
Missing panels under front can mess up air flow. Modified front end could to same.
Ryanap333
Report this Post01-02-2016 12:46 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are no springs on mine
Ryanap333
Report this Post01-02-2016 03:07 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ryanap333
Member since Jun 2015
I miss spoke. When the headlights are on and both of them are up the lids will pop up and down loosely at about 75. I havent actually seen them pop up with the headlights in the off position.
Report this Post01-02-2016 06:06 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still shouldn't move at 70 to 90.
OE Doors have 2 spring on hinge side. Small version of rear lid springs and works about the same.
Ryanap333
Report this Post01-02-2016 06:31 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im going to have to find some suitable springs and figure out a way to rig it then. Unfortunately the dude thats putting my 3800sc swap in has had all the part for three months and has yet to start the install. The 4cyl has been removed from the cradle but it took a while to get all the parts so he took it off the lift. This has been back in june.
