  3rd brake light bulb
3rd brake light bulb by 85fieroguy
Started on: 11-12-2015 07:52 PM
Replies: 6 (1297 views)
Last post by: tshark on 11-14-2015 08:41 AM
85fieroguy
Report this Post11-12-2015 07:52 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Burned out the bulb inside the 3rd parking light , inside rear window, cleaned it up and went to Auto Zone. Thought I's get a LED for more brightness, ...but $26.00 for 2 LED bulbs???? No way..any opinions as to what bulb I should use that's reasonavble to replace the stock bulb for a brighter light ?? Thanks
Kevin87FieroGT
Report this Post11-12-2015 08:51 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wish I could help you more, but there are plenty of sellers on ebay and the like that sell single LED replacement bulbs of all types. Or do a search here on PFF under LED bulbs.
dobey
Total ratings: 371
Report this Post11-12-2015 10:02 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace it with one that fits. any brand new bulb is going to be brighter than a 30 year old bulb that's burned out.
If you don't want to pay the money for an LED, then pay the $3 for the incandescent stock replacement. If you don't want incandescent, then pay the money for LED. Not a hard problem.
Report this Post11-12-2015 10:59 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
889 bulb (25w 540 lumins)? Is bright and hot. Many sells this for low beam HL and fog/driving lights. Dim lamps mean old bulb, wiring problems or both.
MANY sells LED ones to replace 50w bulb and are very bright...
LED here should Not be brighter the 889 bulb because too bright can blind other drivers at night.
Too bright can be stopped by cops same as dim/dead bulbs
color temp above ~4500°K often makes red look pink to purple can get attention by cops too.
See my Cave, Lighbulbs and LED poisoning
css9450
Total ratings: 86
Report this Post11-13-2015 08:22 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just get the regular bulb.
I have the LED one from TLG/Black Top Racing but although its nice and bright, its pink. Bright, but pink. Pale pink. It relies on the red lens of the housing to give it a red color, but its just not happening. I keep forgetting about it but I'm going to switch it back to a regular bulb.
bonaduce
Report this Post11-13-2015 10:21 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I have some red led boards (with leds) left over after I did mine, 2 of these boards (6-8 leds) fit perfectly inside the housing. I attached them to a 1/8 piece of plexiglass with the red leds and lense it is a bright red.
If i do, i will let u know if interested
dan
tshark
Total ratings: 68
Report this Post11-14-2015 08:41 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, LEDs are odd. The red filter doesn't help much, so you need a bulb that is the correct color. Blacktop racing also sells an LED array. It looks red to me. It's the Level 3 option. Not cheap, but it comes with a new housing.
One of the problems with the incandescent 3rd brake light is that it gets too hot, if on for a long time. As a result, the housing melts and warps.
[This message has been edited by tshark (edited 11-14-2015).]
