  Battery died
Battery died by painandgain99
Started on: 11-01-2015 12:07 PM
Replies: 2 (139 views)
Last post by: theogre on 11-01-2015 04:15 PM
painandgain99
Report this Post11-01-2015 12:07 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
So when i took my steering column apart, i didnt have the rools to fix it. So i put it back together briefly and parked it and im not driving it until i fix the column sometime soon. When putting it back together, i forgot to put in the little spring and pin for the horn. So when the column shook, the horn relay went off like crazy (and my horns did once, never heard them work before this) and now a few days later my battery is dead, assuming it sas the horn relay. Is there anything i should do like unplug the battery or horn relay to prevent further damage? I cant jump start it for a couple of days..
87' GT 5 speed 😤 15 years old
My IG for daily motivation: Alpha_Photos
Report this Post11-01-2015 02:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're concerned about an abnormal battery draw and you can't trace it prior to the car sitting for awhile... disconnect a battery terminal (preferably the neg).
Report this Post11-01-2015 04:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
low/dead battery Hates freezing weather. The low battery will easily freeze too. (Full battery won't freeze until well below 0°F)
pull the battery and charge it.
