  Anyone running lowered with 17x8 with 235 40's ???
Anyone running lowered with 17x8 with 235 40's ??? by FIEROPHREK
Started on: 09-25-2015 03:58 PM
Replies: 6 (258 views)
Last post by: California Kid on 09-26-2015 01:05 AM
FIEROPHREK
Total ratings: 137
Report this Post09-25-2015 03:58 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like the topic says Anyone running 17x8's with 235 40's on the front with eibach lowering springs? I'm thinking of going with this combo and have heard that 8's are a little wide for the front when lowered. I'm hoping with the 235 and being a 17" wheel I might be ok. Any insight is appreciated!
12.3 is faster than a 13.2
bkw88
Report this Post09-25-2015 04:16 PM Click Here to See the Profile for bkw88Send a Private Message to bkw88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm running 17x7 with 215/40 17......on my lowered 88. The wheels came from a pre 88 car that was lowered with eibachs. He had no issues, but they were very close to wheel liners at full lock of wheel
It will be awful close with the wider wheel/tire on it.
Hope this helps....
Best of luck
Brian
qwikgta
Total ratings: 84
Report this Post09-25-2015 04:52 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
also running 17x7 on the front of my 88. 215/45/15 dropped low and no issues turning or rubbing. Not sure how 8's would do.
[This message has been edited by qwikgta (edited 10-02-2015).]
Jim88GT
Report this Post09-25-2015 05:15 PM Click Here to See the Profile for Jim88GTSend a Private Message to Jim88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm running 235/17s up front on CT#10 with drop spindles - see the CT#10 thread for pics
zmcdonal
Report this Post09-25-2015 08:34 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year Fiero are you talking about? I am running a 235/35/19 on a 9 inch rim in the front of my 87 with lowering ball joints. My 235 on a 9 inch rim is a decently stretched tire though. I have slight rubbing at full lock due to the 9 inch rim, but I think you should be ok running a 8" with the right offset. It is all going to depend on your offset as well as to where the wheel sits in the wheel well. I think the widest wheel you can fit on the front of a pre88 Fiero is 8.5 inches. I believe that is what Madcurl is running on the front of his silver chop. I have done EXTENSIVE research on wheel/tire size and offset.
Using a tire size calculator, looking at the overall diameter, you will be at 24.4 inches, my setup is 25.5 inches with no issues.
FIEROPHREK
Total ratings: 137
Report this Post09-25-2015 11:07 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm planning on running this setup on an 87 gt with Eibach lowering springs. I'm looking at using enkei kojin wheels with a 40mm offset. I'm going to be running the grand am brake mod for now which should push the wheel out a small bit. Thanks for the replies guys I think I'm going to be good to go!
California Kid
Total ratings: 274
Report this Post09-26-2015 01:05 AM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just for reference you can check out pictures of my '88 GT running 17x8 ASA's with 215x45 frt. and 245x45 rr. Car is lowered slightly lower than lower springs you mention, but it is a firmer setup. outside of tires on frt. slightly rubbed whl house liner at 12 o'clock high. No other issues, corners like crazy.
https://www.fiero.nl/forum/F...1/HTML/025670-8.html
Car History: https://www.fiero.nl/forum/Forum1/HTML/025670.html
