  Where can you get a 3800sc TB Flow Screen
Where can you get a 3800sc TB Flow Screen by don297
Started on: 09-12-2015 04:09 PM
Replies: 4 (175 views)
Last post by: Dennis LaGrua on 09-13-2015 09:18 AM
don297
Report this Post09-12-2015 04:09 PM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
Realized my 3800sc may not be idling right because it doesn't have a flow screen. It is the older style TB so the MAF needs the screen to read airflow better. Anyone know where I can get just the screen? Or if anyone has one I can buy it off them.
Khw
Total ratings: 134
Report this Post09-12-2015 05:19 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check local pic a part lots? The 3800 was used in so many different GM vehicles I would think you could find one there.
[This message has been edited by Khw (edited 09-12-2015).]
Report this Post09-12-2015 07:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's about it but rather than fool with repairing it, I would just replace it. Removing the MAF screen is a very bad modification as it throws the MAF readings out of wack and exposes the wire element to possible damage. If you are looking for a higher flow rate use the early LS1 MAF , import the MAF table into the PCM and tweak the tune.
[This message has been edited by Dennis LaGrua (edited 09-12-2015).]
FIEROPHREK
Total ratings: 137
Report this Post09-13-2015 08:36 AM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 3800na in a 98 grand prix that I removed the honeycomb screen from with no ill effects. Got the car with 103k on it 5 years ago and it now has 266k and running strong. That's just my experience with it though.....
12.3 is faster than a 13.2
Report this Post09-13-2015 09:18 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The MAF is calibrated to work with the screen. Removing it alters the flow pattern and should at the very minimum alter the Air/Fuel mixture somewhat. The engine will run but I have read of fueling changes in the tune resulting from that configuration. The MAF is also calibrated to work with the intake configuration and we usually change that when we do the swap so perhaps both changes neutralized each other. Have you scanned to check the LTFT's or have re-tuned?
