  3.8 Series 2 SC Vin 1 Gasket set?
3.8 Series 2 SC Vin 1 Gasket set? by dcarrd
Started on: 11-21-2014 12:01 AM
Replies: 7 (132 views)
Last post by: LornesGT on 11-28-2014 10:58 AM
dcarrd
Report this Post11-21-2014 12:01 AM Click Here to See the Profile for dcarrdSend a Private Message to dcarrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I had my 3.8 sc Series 2 (Vin 1 out of a 2000 Grand Prix GTP) shortblocked with new bearings, rings and crank. Now I have to put everything back on it. I found a Victor Reinz full gasket set with nitroseal(bead of graphite around the head gaskets) for $280. What is the best option in Felpro and has anyone had experience with the Victor set?
darkhorizon
Total ratings: 450
Report this Post11-22-2014 08:50 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would stay away from the aftermarket head gaskets. The dealer set is pretty cheap and ideal. ZZP also has aftermarket gaskets alcarte that are pretty cheap.
dcarrd
Report this Post11-23-2014 04:23 AM Click Here to See the Profile for dcarrdSend a Private Message to dcarrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow really? so stay away from the performance head gaskets? Ive read some people mention having failures and going with the expensive felpro. I dont mind the reduced cost of the standard set, just trying to find out if its comparable. Is that what you have in yours?
AutoMarshal
Report this Post11-23-2014 08:51 PM Click Here to See the Profile for AutoMarshalClick Here to visit AutoMarshal's HomePageSend a Private Message to AutoMarshalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like Fel-pro........
Valve cover gasket set: #VS50465R $48.31 AD
LIM gasket set: #MS98014T $54.76 AS
UIM gasket set: #MS95744 $10.89 AZ
Conversion gasket set: #CS9917 $21.09 AZ
TB gasket: #61024 $4.89 AZ
Exhaust flange gasket: #61310 $6.24 AD
http://www.fiero.nl/forum/F...2/HTML/000156-2.html
dcarrd
Report this Post11-24-2014 09:13 AM Click Here to See the Profile for dcarrdSend a Private Message to dcarrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
what head gasket did you use?
darkhorizon
Total ratings: 450
Report this Post11-26-2014 05:30 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive used and seen alot of headgaskets...I am currently using the full steel gaskets but i have murdered a set of felpros myself, and seen a few die on buddies cars. The GM gaskets are new to my crew, but they appear much higher quality.
Justinbart
Total ratings: 119
Report this Post11-27-2014 10:37 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Felpro has a 100% success rate on my car.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
LornesGT
Report this Post11-28-2014 10:58 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why is the one set refered to as a conversion set?
