  Rear Inner Fenders and Slash Shields Diagram
Rear Inner Fenders and Slash Shields Diagram by jimmygmartin
Started on: 08-16-2014 04:06 PM
Replies: 8 (645 views)
Last post by: solotwo on 08-17-2014 08:38 PM
jimmygmartin
Report this Post08-16-2014 04:06 PM Click Here to See the Profile for jimmygmartinSend a Private Message to jimmygmartinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone have a diagram showing how the rear inner fenders and splash shields are assembled???
Thanks !
jimmygmartin
Report this Post08-17-2014 09:18 AM Click Here to See the Profile for jimmygmartinSend a Private Message to jimmygmartinEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store sells the rear Splash Shields, you would think that they would have an assembly diagram.
Report this Post08-17-2014 09:59 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The splash shields are installed first, then the wheel well liner.
Use the cutouts for the brake lines and rear toe links [or sway bar (88 only)] to determine orientation side to side and front to back.
jimmygmartin
Report this Post08-17-2014 10:51 AM Click Here to See the Profile for jimmygmartinSend a Private Message to jimmygmartinEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is helpful. They are folded over and stapled by the axel cutouts, I assume the doubled up or folded over portion goes toward the engine. A diagram would be great since the inner fender and the splash shields share some fasteners.
Report this Post08-17-2014 11:01 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
OEM splash shields feature large diameter holes for the shared fastener locations, and small holes for the splash shield only fasteners.
jimmygmartin
Report this Post08-17-2014 11:07 AM Click Here to See the Profile for jimmygmartinSend a Private Message to jimmygmartinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks that is another helpful tip !!
solotwo
Total ratings: 62
Report this Post08-17-2014 02:57 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The supplier for the fiero store is a company I think in PA that makes these for other cars. Not impressed with the 84-87 shields. Some holes were missing, I doubt the factory used staples. Sloppy craftsmanship.
Report this Post08-17-2014 07:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the OEM used staples......
solotwo
Total ratings: 62
Report this Post08-17-2014 08:38 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sloppy craftsmanship on Pontiacs part.
My first encounter with splash shields was for my 88 that I used to have. Got the shields from Rodney. Worked great.
