  Spot for sunroof?
Spot for sunroof? by FieroCanada
Started on: 02-05-2014 02:51 AM
Replies: 6 (346 views)
Last post by: FieroCanada on 02-05-2014 10:50 AM
FieroCanada
Report this Post02-05-2014 02:51 AM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
People say there is place for it in front trunk? I'm not seeing where
Report this Post02-05-2014 07:02 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two tabs on front compartment front wall, two pads on molded plastc cover that covers components on rear wall of front compartment, has rectangular hole in center for latch mechanism.
Someone will post a picture......
Fiero84Freak
Report this Post02-05-2014 08:33 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
All I could readily find is a picture of my own Fiero's front compartment. Look at the picture below;
You see that blade that looks like a bow shape? You remove that. That goes into the tabs in the roof after removing the sunroof to push wind over the sunroof opening. Then with the sunroof deflector blade removed you can install the sunroof up front. It lays flat. If you look at where the jack is on my picture, look directly in front of it. See that little rectangular tab below the molding for the trunk? That's the passenger side hold tab. There is a tab just like it right out of my picture on the driver's side. Then you see towards the right of the picture where that rectangular hole is in the piece that held the sunroof deflector blade? That's where the latch just lays into.
So basically the way you put the sunroof in is with the deflector blade removed from storage, slide the forward tabs of the sunroof into the hold tabs, lay it down so the latch goes into the rectangular hole, and now when you close the hood the pads under it (make sure both the large rectangular pads are in place under the hood) will sandwich it against everything and make sure it doesn't rattle around when you drive.
rogergarrison
Total ratings: 551
Report this Post02-05-2014 09:57 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone post a pic of the sunroof in place. Its worth 1000 words.
The two little pads at the front of the compartment hold the front of the sunroof. After you pull out the deflector, the back of the sunroof sets on those 2 rubber pads on that ledge, with the latch going into that center hole in the ledge.
Khw
Total ratings: 134
Report this Post02-05-2014 10:03 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, here ya go.
[This message has been edited by Khw (edited 02-05-2014).]
rogergarrison
Total ratings: 551
Report this Post02-05-2014 10:15 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroCanada
Report this Post02-05-2014 10:50 AM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thx guys
