  door hinges
door hinges by jon m
Started on: 12-10-2013 12:26 PM
Replies: 1 (282 views)
Last post by: jaskispyder on 12-10-2013 12:57 PM
jon m
Report this Post12-10-2013 12:26 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Just a quick question - I am going to replace the door pins on my 87gt also along with rodneys roller repair kit so that the hinges are completely overhauled.
my main question is the top hinge does the pin go in through the top of the hinge or from the bottom - upwards
or does it matter from which way in goes in ?
Any opinions are always welcomed
jon
jaskispyder
Total ratings: 205
Report this Post12-10-2013 12:57 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the top hinge has the pin come in from the bottom. There is a little clip/flange that keeps it from falling out.l Otherwise, you can't remove the pin if it is put in from the top.
