  coolant heaters
coolant heaters by Charles Schutty
Started on: 12-09-2013 10:13 PM
Replies: 6 (206 views)
Last post by: 2.5 on 12-10-2013 09:24 AM
Charles Schutty
Report this Post12-09-2013 10:13 PM Click Here to See the Profile for Charles SchuttySend a Private Message to Charles SchuttyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't believe the trouble I am having locating a 'tank' heater that uses 120 volts and is located in the lower radiator hose. I am not in favor of using a 'frost plug' heater or a headbolt heater.
. . . . Hope someone here has a link to where I can purchase one (2?) of these.. . . chas
Report this Post12-09-2013 10:41 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You could build your own. Wrap a coolant tube with some resistance wire.....I wonder where to put the plug?
edit: I don't think it would be a good idea to put something in the hose....water flow is critical.
[This message has been edited by Gall757 (edited 12-09-2013).]
Charles Schutty
Report this Post12-09-2013 11:12 PM Click Here to See the Profile for Charles SchuttySend a Private Message to Charles SchuttyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What I have in mind and found earlier tonight online and can't find now is a round device that fits in like a 2" hose and then its main body would be 3" in Dia. The main body would be In the area of 3" long, with the 2" diametet snout on each end being about 3/4" long.. 4-1/2" overall length. The heating elements are in the 'buldge' and don't interfer with the flow. I bet my local NAPA store has 3 dozen on hand....have to check them out in the morn. Thanks for your reply. . . chas
AL68
Report this Post12-09-2013 11:36 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
O'Reily has them - "Zerostart" brand, 1 1/2 hose # is 3200003
jaskispyder
Total ratings: 205
Report this Post12-10-2013 08:15 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post12-10-2013 09:19 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
3 different sizes
http://www.ebay.com/sch/i.h...+heater+110&_sacat=0
Make sure you run at least a 5w oil, even a 0w
[This message has been edited by 2.5 (edited 12-10-2013).]
Report this Post12-10-2013 09:24 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
These are interesting
http://autocoolingsolutions...oling+System+Heaters
There are also engine oil heaters.
http://autocoolingsolutions...t=Engine+Oil+Heaters
