  Quickest Stock Fiero?
Quickest Stock Fiero? by MarkS
Started on: 11-28-2013 11:48 AM
Replies: 21 (1154 views)
Last post by: dobey on 12-11-2013 08:44 PM
MarkS
Report this Post11-28-2013 11:48 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Often thought something like this might be the quickest stock Fiero:
http://www.ebay.com/itm/Pon...98&pt=US_Cars_Trucks
85 2.8 SE 4spd Muncie without any options, no AC no nothing exc a cassette deck maybe.
I swear my 85 GT 4spd was faster than my 86 SE 4spd. The 85 felt like it had more on top.
Happy Thanksgiving!
Mark
86 SE V6 4 speed
86 SE V6 Auto
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
[This message has been edited by MarkS (edited 11-28-2013).]
pontiackid86
Total ratings: 344
Report this Post11-28-2013 12:10 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Formula hands down.
Marko
Report this Post11-28-2013 12:16 PM Click Here to See the Profile for MarkoSend a Private Message to MarkoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Of course it`s the best..................
But I tend to favor them being as I own one.
In all reality, all Fiero models are fun.
Marko.
'85 SE 2M6 Muncie 4 speed.
a.k.a "The Rumble Seat"
MarkS
Report this Post11-28-2013 12:58 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
These cars also make you appreciate the clean handsome design of the original. If I didn't already own 2, I might buy it.
Arns85GT
Total ratings: 202
Report this Post11-28-2013 02:24 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also have the 85 GT with the 4 speed Muncie 3.65. It turned 15.474 on the quarter with me at the wheel and I'm no drag racing genius.
The 3.65 Muncie is the best all out git go tranny, but not great on freeway speeds because the 4th gear isn't really tall enough.
I now have it hooked up to a 4.9 and it is pretty potent. The 4.9 is carb'd with no ECM holding it back.
However, bone stock, I think the 85 GT with no a/c is right up there.
Arn
Bloozberry
Total ratings: 311
Report this Post11-28-2013 03:10 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found my original '86 SE V6 with four speed fine up until it came time to shift to fourth. You could scream it to redline in third but the revs dropped off outside the engine's sweet spot and would bog up shifting to fourth. It seemed to me like there was a huge hole between third & fourth and I didn't like that transmission because of it.
hyperv6
Total ratings: 93
Report this Post11-28-2013 03:19 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
On paper the 85 SE 2M6 manual should be the fastest. It had the highest HP with the lowest weight. But in the end we are only looking at a tenth of a second or two. Under the skin these cars are nearly all the same the body weight was the greatest difference.
When I ran my 85 SE auto I forgot to shut off the AC and it went about a tenth faster. I would have to guess the AC fuel enrichment was still working but the compressor was cut our at WOT. That is all I could guess was in play.
Either way all the V6 cars like almost all 80's cars can not keep up with even some base model 4 cylinders today that have 50-60 HP more. I get out of my HHR Turbo and drive the Fiero it feels like something is wrong with it. LOL!
Blacktree
Total ratings: 350
Report this Post11-28-2013 03:49 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it would be either a low-optioned '85 GT with 4-spd, or an '88 Formula with 5-spd. And between those two, it would probably depend on the type of performance test used. For example, the Formula might fare better in an autocross event or road racing, whereas the '85 GT might have an edge in a drag race.
Old Lar
Total ratings: 214
Report this Post11-28-2013 04:14 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most stock Fieros V6 ran 15-17 seconds in the quarter mile back in the day. Automatics would still be in second gear, usually, and manual cars would get to third (85 mph or so). I have only pushed my 87 GT at Gateway Speedway (1998?) racetrack and was shifting at 5000 rpm ~ 90 mph, if I remember.
Doober
Report this Post11-28-2013 09:43 PM Click Here to See the Profile for DooberSend a Private Message to DooberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Arn
http://www.wallaceracing.com/et-hp-mph.php
Using that as a rough guide - I've checked against known weight/e.t./hp times with 12-15% difference, typically wheel vs flywheel hp - I used 3050 as a weight (driver, etc.), and came up with 162hp, mind you that would be wheel hp... pretty good for an old v6, ~1hp/ci.
katatak
Total ratings: 82
Report this Post11-29-2013 01:14 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree - the "Short Bus" was a blast from start through 3rd - then felt like you opened a compression release in fourth! Later on, the next owner dropped a nice 3.4 in it - then it ran a lot better clear through 4th. That motor is now in a Mera!
Carver1
Total ratings: 62
Report this Post11-29-2013 02:56 AM Click Here to See the Profile for Carver1Send a Private Message to Carver1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Short Bus will never die!
I think it was even quicker after I put it on a diet. Just a little off the top!
88 Formula CJB
84 Fiero 2.8
84 Fiero 2.5
11 Camaro SS/RS LS3 6.2
13 Traverse LS 3.6
12 Silverado Z71 5.3
12 Tahoe LT 5.3
1fast2m4
Report this Post11-29-2013 08:57 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
1985 GT with the 4-speed manual, My 1st did back to back 15.2 1/4's completly stock and it was 15 years old at that point.
The 88 formula might be a more fun car to drive, but you need to make one more shift in the 1/4 mile before the finish. Stock Vs Stock 85 GT will beat the 88 Formula by a few tenths.
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
hyperv6
Total ratings: 93
Report this Post11-29-2013 08:59 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Keep In mind the 85 2M6 SE has the same engine and everything the GT has less the heavier body parts. I think the GT part add about 75-100 pounds. It is splitting hairs but the 2M6 is the lightest Fiero built with the V6.
This has always been a little trivia thing about that model.
1fast2m4
Report this Post11-29-2013 09:15 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
It should be noted that at this Very low performance level, cars with the stiffer WS6 suspension SHOULD be faster because wheel spin won't be much of a issue and the stiffer springs would help the car move forward rather than waste energy squatting in the rear & raising the nose.
jscott1
Total ratings: 415
Report this Post11-30-2013 02:29 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't keep spreading this old wives tale. There is nothing on the fastback that's going to add 75-100 pounds over the 85 2m6 SE notchback. The whole fastback clip doesn't weigh more than 40 pounds and I doubt there is 2 pounds difference between it and the notchback clip. I've done a fastback conversion and personally picked up every part and I know I did not put on 75-100 pounds.
Real data shows it's more like 13 pounds
https://www.fiero.nl/forum/A...040223-2-039394.html
[This message has been edited by jscott1 (edited 11-30-2013).]
1fast2m4
Report this Post11-30-2013 08:25 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
13lbs for the clip but there's more to it than that, the 86gt VS. 85 2m6 the 85 has 14" wheel vs 15" the fastback engine grates are bigger what's the 5 speed weigh VS the4 speed? and I'm sure if someone had the production #'s most of the Fastback cars will be higher optioned (A/C, Cruise control, sunroof, Rear defogger, power mirrors & Power windows) where as your chances of not getting all the bells & whistles go up in the 85 2m6 or even a lower optioned car like the one the OP posted the Ebay link to.
Fastbacks might not be a full 100lbs heaver, but they are a good 80lbs more
[This message has been edited by 1fast2m4 (edited 11-30-2013).]
hyperv6
Total ratings: 93
Report this Post11-30-2013 08:33 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not wives tales just numbers that I saw from Pontiacs own data. years ago.
Either way the SE is lighter no matter how you slice it and as I have already clearly stated here when you come down to it this is just splitting hairs no matter 13 pounds or 100 pounds.
Also you have to consider when Pontiac did those numbers did they use a SE with no Air and many of the other standard options that the GT had etc? If you have an issue call them as that is where it originally came from.
To be fair the numbers were listed for the 85 back in the day so this did not even include the Fastback as per their numbers.
[This message has been edited by hyperv6 (edited 11-30-2013).]
johnyrottin
Total ratings: 85
Report this Post11-30-2013 09:18 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
SACRILAGE!!!!!
LOL
jscott1
Total ratings: 415
Report this Post11-30-2013 08:02 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
As you have stated many times not even the folks at Pontiac are infallible when it comes to stating bad information. But this weight topic has been debated to death. I'm just saying that if you did an apples to apples comparison the fastback adds negligible weight. Less than 15 pounds to be sure.
Australian
Report this Post12-11-2013 05:23 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Total ratings: 371
Report this Post12-11-2013 08:44 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
For just the clip, yes. But for the whole cars, as shipped from the factory, not so much. That 200 lb curb weight difference between the lightest and heaviest models has to come from somewhere. The "fastacks" being all GTs, all had heavier suspension, all had 15" wheels instead of 14 or 13, and all had more standard options than were on the notchback cars.
The 85 GT might not have been that much heavier than the 85 2m6, but the 86-88 GT would have been well more than 13 lbs heavier. Especially the 87-88 cars, with the larger fuel capacity. Even an 88 coupe would be ~13 lbs heavier than an 85 coupe, both with the exact same options, and a full tank of gas.
What's the difference in weight for the wheels? Suspension? Brakes? Interior trim? All the other options? Those 200 lbs aren't for marketing.
