  3800sc or NA for turbo setup
3800sc or NA for turbo setup by addysvan1987gt
Started on: 08-30-2013 12:35 AM
Replies: 12 (489 views)
Last post by: qwikgta on 09-03-2013 12:54 PM
addysvan1987gt
Report this Post08-30-2013 12:35 AM Click Here to See the Profile for addysvan1987gtSend a Private Message to addysvan1987gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which motor would be best for the use of a turbo setup and why. I really need tips and suggestions. I'm a total n00b when it comes to this and I want to do EVERYTHING correctly. I have not done anything to my car yet as I am trying to figure all this stuff out first and its coming across a bit confusing. Perhaps I need to make notes which is definitely what I will be doing this time around. I have posted things before but I feel like I have not gotten anywhere. I would like this time to be different. Thank you all in advance for your helpful insight and knowledge.
nitroheadz28
Total ratings: 94
Report this Post08-30-2013 01:00 AM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.fierosearch.com/...urbo&Action=DoSearch
Don't be lazy. Take action and you will see results.
addysvan1987gt
Report this Post08-30-2013 01:08 AM Click Here to See the Profile for addysvan1987gtSend a Private Message to addysvan1987gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... this is embarrassing. Thanks google. You've let me down again. Thanks friend.
nitroheadz28
Total ratings: 94
Report this Post08-30-2013 02:58 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
The search tool can suck sometimes, but use different word combinations along with the title+ author/ post search. There is so much info out there, you'll find everything you could ever need in 15 mins of reading.
Boostdreamer
Total ratings: 98
Report this Post09-01-2013 02:51 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just did a search for you in all active forums and archives.
I searched for "turbo 3800NA" and also "turbo L36"
I got ZERO returns on both.
Now I'm curious about it.
Jonathan
My '85 L67 Build Thread
Justinbart
Total ratings: 119
Report this Post09-01-2013 03:13 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
mattwa
Total ratings: 88
Report this Post09-01-2013 03:28 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm also in the process of building my own 3800 Turbo setup. Start with an L67/L32 or you may see carnage like Justin did. I got a 99 L67 with 74k on it for $500, mostly complete. Then I stripped it down to the shortblock and scrapped 50% of what I took off...haha.
NoMoreRicers
Report this Post09-01-2013 07:33 PM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget LFiero67 is running low 10s on an L36.
Justinbart
Total ratings: 119
Report this Post09-01-2013 08:16 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't heard of any L36 engine blowing up but I've heard of many many L26's breaking rods.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
Boostdreamer
Total ratings: 98
Report this Post09-01-2013 10:00 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
https://www.fiero.nl/forum/A...130314-2-115323.html
So, in your linked thread, you were pretty ho-hum about this failure and the need to swap engine blocks. What is your present stance on this issue? Would you recommend putting a turbo on a L36?
Jonathan
nitroheadz28
Total ratings: 94
Report this Post09-02-2013 12:29 AM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thats cause you didn't click the "entire thread" filter, otherwise you wont get many results. Its a pain to sift through sometimes I'll give you that.
Justinbart
Total ratings: 119
Report this Post09-02-2013 11:55 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would try to get a supercharged bottom end first. I haven't seen any L36's fail so I wouldn't hesitate to try one out if I had to. The L26 seems to start breaking things over 450hp so as long as your goal was under that It would probably be find. I still think it's a good candidate for a "top swap". You'll never find the limit with an M90.
11.17@132.6
qwikgta
Total ratings: 84
Report this Post09-03-2013 12:54 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
