  Buffing enamel paint- What compound to use?
Buffing enamel paint- What compound to use? by tesmith66
Started on: 08-09-2013 08:13 AM
Replies: 2 (1559 views)
Last post by: BlackEmrald on 08-09-2013 03:23 PM
tesmith66
Total ratings: 135
Report this Post08-09-2013 08:13 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
What buffing compounds and pads do you guys use to buff fresh enamel? I have sanded with 1200 grit and was using Maguiar's Mirror Glaze medium cut with a foam pad, but it's not working very good. It takes a LOT of compound and pressure to get anything to happen. Do I need something more aggressive?
1986 SE Aero coupe.
Firefox
Total ratings: 240
Report this Post08-09-2013 10:47 AM Click Here to See the Profile for FirefoxSend a Private Message to FirefoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use 3M Super Duty Rubbing Compound on a tan foam pad. I have a partner that prefers a wool pad and he gets great results, too, but I prefer the foam. Takes a bit more time but the wool can cut faster creating potential burns faster. It's a preference thing. After the Super Duty I use a 3M Machine Glaze on a black foam pad and then a 3M Microfinishing Compound as a final swirl remover before 3M Imperial Hand Glaze to finish it off.
It's a lot of work but it works well. I avoid enamel as much as possible and much prefer the urethanes instead as enamels are not very easy to work with.
Good luck!
Mark the paint guy
BlackEmrald
Report this Post08-09-2013 03:23 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have only used 1200, I would recommend doing 2000 then 3000 wet. That is called a color sand. Make sure you use a DA, not just a regular sander.
THEN, use the 3M stuff like suggested. I like the compounds in the purple bottles, if you can find them.
