  It will be a long night in the shop...
It will be a long night in the shop... by AL87
Started on: 08-02-2013 08:42 PM
Replies: 6 (587 views)
Last post by: 1984whitesc on 08-06-2013 02:05 AM
AL87
Report this Post08-02-2013 08:42 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
All of this just to replace a leaking torque convertor seal...
EvilSqueezles
Report this Post08-02-2013 10:52 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks about right I'm always happy that our cars are so easy to take apart its stupid. Takes some time and grunting, but I'd rather have our route than messing around under a car to remove the trans bolts or the whole trans/motor together. Best of fortunes getting her fixed.
~James
[This message has been edited by EvilSqueezles (edited 08-02-2013).]
AL87
Report this Post08-02-2013 11:03 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well... I thought it was the torque convertor seal... BUT ITS NOT.
looks like a little of the bearing from the convertor scored onto one of the shafts, does anyone think I can salvage the trans?
(If not, I have a perfectly fine 88 transmission sitting right next to this, and I can put it in if I have to, and junk this one)
something to do with the alignment between the trans and convertor when it locks?
[This message has been edited by AL87 (edited 08-02-2013).]
crashyoung
Report this Post08-03-2013 05:33 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any slop in the splined shaft?
AL87
Report this Post08-03-2013 06:56 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
there is absolutely no play on that shaft...
I will pull the torque convertor off the motor and check the flexplate for any warpage.
before this, I used to bumpshift up and down the gears on the trans. idk if that had anything to do with this.
AL87
Report this Post08-05-2013 06:53 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hard work pays off. ^_^
1984whitesc
Report this Post08-06-2013 02:05 AM Click Here to See the Profile for 1984whitescClick Here to visit 1984whitesc's HomePageSend a Private Message to 1984whitescEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you thought about putting a 440T4 trans in your GT?
