  fiero brake lines
fiero brake lines by jhsr390
Started on: 07-10-2013 06:22 PM
Replies: 6 (466 views)
Last post by: jaskispyder on 07-11-2013 11:51 AM
jhsr390
Report this Post07-10-2013 06:22 PM Click Here to See the Profile for jhsr390Send a Private Message to jhsr390Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do the lines for the front brakes have a different i.d. than the lines for the rear brakes. Any response appreciated.
J
h.d.fire
Report this Post07-10-2013 10:31 PM Click Here to See the Profile for h.d.fireSend a Private Message to h.d.fireEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced all the lines on my 86' this spring with a stainless steel kit from the Fiero Store,
as I recall they all were the same diameter.
dominic355
Report this Post07-10-2013 11:03 PM Click Here to See the Profile for dominic355Send a Private Message to dominic355Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just got these set of SS lines. All appear to be the same diameter...
jb1
Report this Post07-11-2013 02:14 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered same ones..
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
Marvin McInnis
Total ratings: 227
Report this Post07-11-2013 11:23 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. Most automotive and aircraft brake systems transmit pressure, but very low volume. 3/32 inch inside diameter is typical.
RWDPLZ
Total ratings: 305
Report this Post07-11-2013 11:45 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The line under the car is larger than the lines at each wheel. I made a thread a while back about brake line sizes and fittings, I'd pull it up but I don't have access to a computer right now (phone)
jaskispyder
Total ratings: 205
Report this Post07-11-2013 11:51 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Metal or rubber lines?
Metal lines are the same on all four corners. Line running from front to back is larger.
