  3800sc 5speed. whats your favorite clutch?
3800sc 5speed. whats your favorite clutch? by 84fierored
Started on: 02-23-2013 11:05 PM
Replies: 20 (606 views)
Last post by: fierosound on 12-03-2015 11:06 PM
84fierored
Report this Post02-23-2013 11:05 PM Click Here to See the Profile for 84fieroredClick Here to visit 84fierored's HomePageSend a Private Message to 84fieroredEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking at stage 2 clutches for the factor 86 5speed and I'm in a pickel between spec and centerforce. What have you guys used and what's your favorite? I need to find one for my project 3800sc. Thanks guys!
Justinbart
Total ratings: 119
Report this Post02-23-2013 11:10 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do not use Centerforce.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
MstangsBware
Total ratings: 459
Report this Post02-24-2013 12:03 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
SPEC 3 or SPEC 3+....I have used SPEC on all the 5 speed swaps I have done..
Steel
Report this Post02-24-2013 01:00 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spec S5
bmwguru
Total ratings: 131
Report this Post02-24-2013 05:11 AM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spec stage 3+ is my favorite for daily driving and grip.
www.hausofguru.com
ls3mach
Total ratings: 222
Report this Post02-24-2013 08:09 AM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had 2 spec 3. One in an LQ1. The other in my L67. Not really very helpful other than, I've used them.
bmwguru
Total ratings: 131
Report this Post02-24-2013 08:43 AM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stage 3 had chatter issues and couldn't hold the torque. The 3+ fixed that
Dave
88lambofiero
Report this Post02-24-2013 01:31 PM Click Here to See the Profile for 88lambofieroSend a Private Message to 88lambofieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am helping with the project. I have one ????, do we need to use the 2.8 or the 2.5 clutch? His was a 2.5 5 speed which would make his a Isuzu tranny the 2.8 have the getrag right? Dose the mean the 2.5 is the one that needs to be used.
Thanks
GeMs
Report this Post02-24-2013 09:19 PM Click Here to See the Profile for GeMsSend a Private Message to GeMsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a spec 3 in my stock swap.
It was an older version, and all the springs popped out.
Swapped to a Clutchnet Costum clutch, and haven't had a problem since.
Bfisher31286
Report this Post02-25-2013 03:16 PM Click Here to See the Profile for Bfisher31286Send a Private Message to Bfisher31286Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had the centerforce at first and it wouldnt hold the power at all on a stock 3800sc. I built up the motor a bit and was reluctant on getting the SPEC stage 4 unsprung, but that is what I went with. I am glad I did because the chatter is minimal and the pedal feel is not that stiff. I would recommend the clutch to anyone who is planning to add any power-adders in the future.
Steel
Report this Post02-25-2013 05:44 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whats the other turbo manual guys running?
I think Justin has a spec 5, any others?
84fierored
Report this Post02-25-2013 06:13 PM Click Here to See the Profile for 84fieroredClick Here to visit 84fierored's HomePageSend a Private Message to 84fieroredEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ended up going with a spec 2+ thanks guys. It should hold up since its for mosty a daily driver not a racer.
Justinbart
Total ratings: 119
Report this Post02-25-2013 06:18 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like my stage 5 but there is only 2-3 of us that need it. The 3+ sounds like a winner for any mild setup.
11.17@132.6
Steel
Report this Post02-25-2013 06:26 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you going to the grand prix meet this spring?
Justinbart
Total ratings: 119
Report this Post02-25-2013 07:46 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
belle isle? I plan on it.
11.17@132.6
FieroFastBackL67
Report this Post12-01-2015 04:53 AM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stupid question maybe? I have Rogers flywheel for the 3800sc and Im using the getrag trans couldn't figure out which clutch I buy. I'll be more specific.. The flywheel is from a firebird I think? So do I buy a firebird pressure plate and Fiero clutch? I'm confused.
[This message has been edited by FieroFastBackL67 (edited 12-02-2015).]
84fierored
Report this Post12-01-2015 05:33 AM Click Here to See the Profile for 84fieroredClick Here to visit 84fierored's HomePageSend a Private Message to 84fieroredEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to buy them for the getrag your using.
Report this Post12-01-2015 04:11 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney sells a flywheel? Got a link?
FieroFastBackL67
Report this Post12-02-2015 09:15 AM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whoops that's a typo.. I fixed it. I meant Roger. If your looking for a flywheel its here https://www.fiero.nl/forum/Forum4/HTML/068855.html
AutoMarshal
Report this Post12-03-2015 10:51 PM Click Here to See the Profile for AutoMarshalClick Here to visit AutoMarshal's HomePageSend a Private Message to AutoMarshalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went with the Spec 3+. After the 500mi break in period of city driving and no WOT, I am very very happy with my choice! No slipping, no chatter, and it holds the power. I bought the clutch off of Amazon.com part#SC883F for $418.49, well worth it!
I got the clutch and flywheel bolts from the local GM dealership.
Clutch bolts: part# 24571667 $2.60 each times 6= $15.60
Flywheel bolts: part# 24505092 $3.20 each times 8= $25.60
Torque specs:
flywheel: 11 lb/ft + 50* (I like to use a bit of red thread lock on the bolts)
clutch: 15 lb/ft + 45* (I like to use a bit of red thread lock on the bolts)
https://www.fiero.nl/forum/F...2/HTML/000156-4.html
fierosound
Total ratings: 286
Report this Post12-03-2015 11:06 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a Spec Stage 2. Lots of pressure and heavy pedal effort but held well.
Had a problem with clutch release bearing collapsing for some reason.
Replaced it with a Bully Stage 3 - high clamping with low effort. Love it.
A friend here used same clutch as me with his 3800 S/C and is thrilled with it.
https://www.fiero.nl/forum/Forum2/HTML/129057.html
