| | | quote | Originally posted by D3M6B:
I say this because your generalization that this is a democratic led push. Is based on assumptions and stereotyping of the state.
You could be right. However prese ting your argument the way in which you are. Clearly illuminates your ignorance.
Less than 2 more minutes of research on YOUR part would have cleared things up for you.
"The initiative’s sponsor, a group called End Animal Cruelty,
is beginning to gather the 112,000 signatures they’ll need by next summer and
is working through the national progressive network ActBlue
to recruit volunteers for the effort, animal activist David Michelson recently told Portland’s KBOO-FM, a donor-supported radio station."https://www.farmprogress.co...l-slaughter-breedingBy the way, the "IP13" label
should have also been a big clue for you that the idea is a PROPOSAL / BALLOT INITIATIVE and not a
HOUSE BILL as you
assumed.
Accordingly it would NOT be found where you directed people to look.
The OP also did NOT specify what
political party he thought was pushing the issue. That
wrong assumption was all YOURS.
All of the above "
Clearly illuminates your ignorance", not his.
[This message has been edited by randye (edited 04-25-2021).]
