  The Mall
  Looking for P-Seals
Looking for P-Seals by Mini_moosee
Started on: 03-31-2021 12:23 PM
Replies: 2 (516 views)
Last post by: swing69 on 04-02-2021 07:51 PM
Mini_moosee
Report this Post03-31-2021 12:23 PM Click Here to See the Profile for Mini_mooseeSend a Private Message to Mini_mooseeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for T-Top P-Seals for each side. Saw that Fieroparts.com used to make reproductions on an older post but the site has since gone under construction.
1987 Silver T-Top
1988 White T-Top (Gone)
1993 Chevy Lumina (Gone)
dremu
Report this Post03-31-2021 01:42 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get P-shaped rubber seal inexpensively and cut to length. Will require a smidge of razor blade work in the center but it's easy enough.
https://www.mcmaster.com/1142a11
was the one I used, but they have lots should you want something slightly thicker/taller/whatever
https://www.mcmaster.com/catalog/127/3776
-- A
swing69
Report this Post04-02-2021 07:51 PM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
be patient. they show up on ebay every so often.
