  fitting digital gauge in original speedo or. when iam bored part II (Page 1)
fitting digital gauge in original speedo or. when iam bored part II by Fieromaniac
Started on: 04-11-2007 05:22 AM
Replies: 70 (5153 views)
Last post by: Fieromaniac on 05-27-2009 01:21 PM
Fieromaniac
Report this Post04-11-2007 05:22 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
half year ago i had a plan......
creating this by using a bicyclecomputer
features :
Total KM or MLS
Trip KM or MLS
Speed KM or MLS
average speed
topspeed
time driven
Processor of this BC can calculate up to 270km/h correct . Somebody told me , or maybe i read it here , that a "Duke" never goes that fast
So that should be ok.
so i bought a Sigma BC800 from E-Bay and took my dremel
after some worke it looks now that way
iam getting to it
just to test if it still fit
This images is larger than 102400 bytes. Click to view.
Plasmafolia is next step
then ill connect it to the BC sensor which i fixed on 1 axle .
updates follow
[This message has been edited by Fieromaniac (edited 04-11-2007).]
jscott1
Total ratings: 415
Report this Post04-11-2007 11:31 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool and interesting idea. I hope you can take some better close up pictures when you are done.
Fieromaniac
Report this Post04-11-2007 12:39 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok iam done with the Speedo
took me a sheet plasmafilm , my Inkjetprinter , and inkjetfilm
Plasmafilm is white and when activated deep blue
Speedo in Dash
now i try the plasmafilm backlight then ill be done for today
Fieromaniac
Report this Post04-11-2007 03:21 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieromaniac
Member since Nov 2006
hmmm couldnt sleep so i finished the RPM / Oilpressure gauge too ....
..... i think iam obsessed .... i should join anonym fieroholics .....
further pics follow
Emc209i
Total ratings: 225
Report this Post04-11-2007 03:37 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Beautiful!
Fieromaniac
Report this Post04-11-2007 03:43 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Materialcosts so far:
BC800 - Ebay 9 €
Plasmafolia - Ebay 21€ inc. inverter
Inkjetfilm - 9 € discounter
+ some other small stuff = 45€ round about
Emc209i
Total ratings: 225
Report this Post04-11-2007 04:13 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Explain how the layers work, I assume you just printed black ink on a layer above the one that glows?
Fieromaniac
Report this Post04-11-2007 04:34 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
plasmafolia
http://cgi.ebay.de/Leuchtfo...QQrdZ1QQcmdZViewItem
i only printed the black parts on transparent waterproved printerfolia
Fiero1Fan
Total ratings: 100
Report this Post04-11-2007 04:36 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks really good!!
Dodgerunner
Total ratings: 323
Report this Post04-11-2007 05:22 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very neat idea, are you going to have to build very much of an interface to connect it to the speedo feed?
chaosfinity
Report this Post04-11-2007 10:58 PM Click Here to See the Profile for chaosfinitySend a Private Message to chaosfinityEdit/Delete MessageReply w/QuoteDirect Link to This Post
So this film works with just an electric current passing through it?
jscott1
Total ratings: 415
Report this Post04-11-2007 11:00 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds like he is going to mount the sensor on the axle and use the built in computer to calculate the speed. As long as you can iput the diameter of the tire accurately it should work.
Dodgerunner
Total ratings: 323
Report this Post04-11-2007 11:16 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya that would work, so it must just use a magnetic transducer. I'd think about using the vss pulse, divide it with an ic to what it needs and adjust the signal for the input. That way you'd have the best of both worlds. Hope the pickup is a hall effect switch and not a reed switch. It will not last at the speeds of an axle otherwise.
Fieromaniac
Report this Post04-12-2007 12:23 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes iam using the Magnet + Sensor system of the Display.
i also thought of using the VSS but , iam running on 225/55 R16 and if u can see in my Tire / Speed table
www.format-service.de/trannyspeeds.htm the tach has a big variance to the standard 215/60 R14 and this is no linear variance so that u could set the speedoneedle just 10kmh forward .
I think i will test fit the gauges this afternoon (plasmafolia worked , i tested alrdy )
I will change the inner instrumentcluster vs st. like this http://www.tuningforyou.de/...b2cf7b48545bc7467c96
and move the displays so that i get space for a lil TFT in the middle for a front camera with IR Mode and a rear cam.
[This message has been edited by Fieromaniac (edited 04-12-2007).]
Dodgerunner
Total ratings: 323
Report this Post04-12-2007 12:32 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hummmm, ya well my name is Zink, but if I could only read German! darn.
Fieromaniac
Report this Post04-12-2007 12:33 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes you can put in the Circumference in Millimeters
here is the page of the producer
http://www.sigmasport.com/u...e=2&typ=bikecomputer
jscott1
Total ratings: 415
Report this Post04-12-2007 01:19 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a very cool idea and opens up a lot of possibilites.
You might be able to rig the cadence to operate as the tach by putting a sensor on the harmonic balancer. I could probably think of 10 other uses for the bike computer given time, this is awesome.
Fieromaniac
Report this Post04-13-2007 06:28 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel and coolant Temp done , getting switches for the Displayfunctions and a new 7.12 MHz Quarz for the 240 Kmh scale
ltlfrari
Total ratings: 127
Report this Post04-13-2007 07:02 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
For all those of you looking for the same stuff in the US now !!
http://www.cooltronix.com/shop/en-gb/dept_3.html
Dave E
www.ltlfrari.com
Fieromaniac
Report this Post04-13-2007 07:24 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
i think ill integrate more digital stuff
digital water and volt gauge is already ordered . thats the way it could look
----photoshop----
PerKr
Report this Post04-13-2007 08:50 AM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is really cool. I've thought about using a bicycle computer as a speedometer, but your installation looks way more sophisticated than what I was thinking of. Nice work.
A few questions though:
1) how do you supply the BC with power? A battery could be used but needs to be replaced from time to time and might be hard to get to.
2) how do you control the BC? Buttons on the dashboard?
Fieromaniac
Report this Post04-13-2007 11:05 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Powercomes from a little Transformator / powersupply and goes through a 3V Akkupack to the BC .
Powwersupply is from Conrad electronics and give exact 3V without Peaks or fluctuations.
controlled is the BC with 3 Push buttons , that i mounted on the right side of the dash (where the electrical Decklid opener is)
Ill take some Pics.
AP2k
Report this Post04-13-2007 11:50 AM Click Here to See the Profile for AP2kSend a Private Message to AP2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bleh, it doesnt come in green.
Fieromaniac
Report this Post04-13-2007 01:10 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
relight my fire .....
BobadooFunk
Total ratings: 128
Report this Post04-13-2007 09:28 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
sweet.
fierohoho
Total ratings: 221
Report this Post04-14-2007 08:34 AM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool thread, one question though, will you be able to dim the display?
AP2k
Report this Post04-14-2007 01:11 PM Click Here to See the Profile for AP2kSend a Private Message to AP2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using pulse-width modulation, yes.
Fieromaniac
Report this Post04-14-2007 05:14 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
the Display of the BC is backlighted by the original dash lights and these can u dim .
u can also dim the EL Foil / Plasma foil
Fieromaniac
Report this Post04-14-2007 05:24 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieromaniac
Had some time today and my old instrument cover looked at me so i bought me a 2 mm Aluminum plate and had some fun
jscott1
Total ratings: 415
Report this Post04-14-2007 07:50 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fieromaniac:
Had some time today ...
That looks great, but I think you have WAAAAY too much time on your hands.
Fieromaniac
Report this Post04-18-2007 08:20 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed the cluster today
need to relocate the sensor i almost lost the magnet
funny thing is that u can read the display better in the night than on day
Jax184
Total ratings: 111
Report this Post04-18-2007 08:50 AM Click Here to See the Profile for Jax184Click Here to visit Jax184's HomePageSend a Private Message to Jax184Edit/Delete MessageReply w/QuoteDirect Link to This Post
EL sheet lighting is nothing new. It's been around for decades. If you poke around online, you can find the stuff in green.
chaosfinity
Report this Post04-18-2007 11:46 AM Click Here to See the Profile for chaosfinitySend a Private Message to chaosfinityEdit/Delete MessageReply w/QuoteDirect Link to This Post
You had to remake your water and fuel gauges?
Fieromaniac
Report this Post04-18-2007 11:55 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes , EL-Foil on the Temp fuel gauge was damaged so i fitted this here
i also changed the odometer to match the miles of my car ( 103k)
[This message has been edited by Fieromaniac (edited 04-18-2007).]
Fieromaniac
Report this Post04-22-2007 01:51 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
mounted the Sensor with Epoxid powergum
and made several Testdrives to calibrate both Speedos to match with my GPS
if Speedo shows 200Kmh real Speed is 196 and thats very good i think
but i need to install some LED to improve the readability of the Display
[This message has been edited by Fieromaniac (edited 04-22-2007).]
Fieromaniac
Report this Post04-28-2007 01:58 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
building a 2nd cluster now
this time i will use a backlighted Digital Display and a digital Volt / Temperature Gauge
jscott1
Total ratings: 415
Report this Post04-29-2007 04:06 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You got your Fiero up to 200 KPH? I wish I lived in Germany
Fieromaniac
Report this Post04-29-2007 04:29 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
sure , it takes some time( no wind from front and no fat Passengers , and i need to jam the Headlightdoors before i want to travel faster than 160KmH ) to get it to 200 but most time , Autobahn is too full so normally i drive around 150 when i make my daily Trip to work.
9,5 L / 100KM = 2,508Gallon / 100km = 2.508 G / 62,15 mls = 24,78 mpg measured last 4000mls 50% Ethanol / 50% Premium Gasoline
with premium gas only i get
8,4L/100km = 2,2176Gallon /100KM = 2,2176Gallon / 62,15 mls = 28,07 mpg
Thats with the black 87SE
my blue 84 4Speed never see speeds beyound 140kph because RPM is getting >4500 then
muncie Performance nearly same accelleration like 88 V6 Getrag
but lousy mpg if u need to drive at least 120 - 130 kph if you want to use the middle lane and not the Trucklane ( 7-8 o clock and 17-18 )
[This message has been edited by Fieromaniac (edited 04-29-2007).]
Hudini
Total ratings: 165
Report this Post05-02-2007 09:58 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are there any other mods to the engine or ECM to handle the 50% ethanol you are running?
Fieromaniac
Report this Post05-04-2007 04:36 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
no Ethanolspecific mods , just performance mods and new fuelfilter
its a DIS L4 so i dont need to change ignitiontiming
[This message has been edited by Fieromaniac (edited 05-04-2007).]
