  S10 blazer knuckle nonsense.
S10 blazer knuckle nonsense. by ericjon262
Started on: 07-18-2025 10:47 PM
Replies: 0 (34 views)
Last post by: ericjon262 on 07-18-2025 10:47 PM
ericjon262
Total ratings: 67
Report this Post07-18-2025 10:47 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
a while back someone posted on facebook claiming S10 blazer knuckles fit on 84-87 Fieros, out of curiosity, I picked up a knuckle and scanned it, and a stock Fiero spindle scanned them with my Einstar 3d scanner, I aligned the two scans approximately on the plane of the lower ball joint bosses, approximately on the kingpin axis since the lower ball joint will determine ride height, provided below is a brief overview of my findings, what I can say without question, is that these to not fit directly, and will require other car modifications, and may have adverse handling results.
The good:
-these would lower the car about 1/2"
-allows for a couple of different wheel patterns
-drop spindles are also available.
-kingpin inclination axis is close to, if not the same as stock.
the bad:
-stock early Fiero ball joints are completely out of the question, in the pictures you can see stock ball joints hitting the spindles, and the tapers aren't even touching.
-the tierod boss is moved significantly, I haven't analyzed this for bump steer or other issues, but I suspect it wouldn't steer nicely
-the upper ball joint is over an inch higher, which will change roll center and camber characteristics.
-depending on the thickness of the brake rotor, the wheel mounting surface is ~5/8" inboard.
[This message has been edited by ericjon262 (edited 07-18-2025).]
