| | | quote | Originally posted by abitsma:
I just bought a '88 Iron Duke and I'm super happy to be a part of the fiero community. Picking it up I knew that it would have some issues (as I got it for a steal of a price) but when it's running and driving it does super well. The issue I want to diagnose right now is that the engine oftentimes doesn't want to idle- it wants to sputter out and stall. I started replacing vacuum lines- and I know I've fixed a pretty good handful of leaks already. I wouldn't be surprised if there were more, but I don't know for sure. My Fiero is also throwing a code 45, rich exhaust, and I'm wondering if the engine stalling and the code are correlated. My potential thoughts right now are that I need to clean/replace the O2 sensor, check for more vacuum leaks, and potentially mess with the IAC..? Problem is- I'm totally new to this kind of stuff and I have no idea where to look for the IAC.
If anybody has any suggestions on how to fix the stalling idle please let me know! |
Hi! Best bet if you're getting a code 45, is to just replace the O2 sensor. They're fairly inexpensive. Get something like a BOSCH or a DELCO-REMY / AC DELCO / DELPHI.
As for the IAC, it's under the air cleaner, attached to the TBI unit. It has a 4-pronged connector on it, and it needs to be specific to your year. Sometimes people replace them from a different engine or GM car, or even forget to re-install the spacer, and then the Idle Air Control valve cannot properly adjust the idle air... so you get what you're getting now... almost stalling.
Let me search for a picture and I'll edit / update this post.
EDIT: Ok, I'm having trouble finding what I'm looking for... but this is your TBI unit (which is located under the air cleaner):
(Note: these are not my hands, not my TBI unit... I just pulled this off of eBay)
There is a sensor / actuator (as you know) called the Idle Air Control valve. It looks like this (Rock Auto):
https://www.rockauto.com/en...rol+(iac)+valve,6072
Looks like there are two torx screws that hold it down, and it should just slide out.
[This message has been edited by 82-T/A [At Work] (edited 09-17-2024).]
